Question about Sport & Outdoor - Others
What is difference between empathetic versus sympathetic?
  • 1,511 Answers
Being Sympathetic is kind hearted, compassionate, sensitive, and benevolent. Assumed is Empathetic or Vicarious; and when used in a special context it has the same values as being sympathetic.
Posted on May 09, 2014
  • 4,018 Answers
Empathetic is when you can place your self in there shoes and fell what they feel.
sympathetic is when you sorry for the person. like a person dies and you appoagise to the family for there lose.
My husband is on probation and we have a no contact order we got pulled over last night and he went to jail for probation violation Is a U felony how much time could he get
You need expert legal opinion of the legal position where you are as laws and attitudes could differ greatly in different areas.
Much will depend on whether an overworked court takes the recommendation of the authorities and simply rubber stamps them or whether you have legal representation in court and your story can be heard - if you have a story.
If your disobedience to the order was wilful the court is unlikely to be sympathetic but if a set of circumstances exist that compelled you to be together for the briefest time possible, a good excuse for breaking the order, such as a family emergency, the court is likely to be more sympathetic and the result could be a shorter sentence or even no sentence at all.
For the wilful disobedience of a probation order the judge could possibly rule the probation term be served in jail - again, whether the no contact order was made for a particular reason, to prevent domestic disharmony or criminal activity, and who made the order and whether it was fair and so forth could perhaps be presented as mitigation.
Feb 08, 2018 | Time Computers & Internet
Tip
Restoring antique furniture sympathetically
If you have unpainted antique furniture, please don't sand it to restore it if you do you remove all the years of gentil removal of the soft timber that has gone& the result is you sand all the hard material that is now raised this is called patina, the result is a piece that now effectively looks like new may as well have a reproduction piece. To do a sympathetic restore buy some steel wool which you can buy in different grades fron 000-3 or 4 being the most course, use metho & thinners 1/2 & 1/2 to remove the old shellac or varnished effect, drying it off wth rags as you go, finally wipe over wth just metho to get it all real clean then once totally dry maybe the next day either wax or French polish to Finnish off.
my personal opinion is there are some real nice waxes out there that not only look good but smell wonderful.
just a footnote make sure you use the steel wool in the direction of the grain, if you go against the grain you will scratch the timber & it takes a lot of work to bring it back. Good luck with your next restoration.??
on Mar 16, 2017 | Furniture
What are the trending technologies of 2017?
Nowadays we are amazed that there are so many amazing technologies we have available to us. 7 Technology Trends in 2017 share with you .
1.IoT and Smart Home Tech.
2.AR and VR.
3.Machine Learning.
4.Automation.
5.Humanized Big Data. (visual, empathetic, qualitative)
6.Physical-Digital Integrations.
7.Everything On-Demand.
source from http://blog.router-switch.com/2017/10/7-technology-trends-2017/, you can click for more detail.
Dec 01, 2017 | The Computers & Internet
What's The Difference When I Buy Something Using My Pin Number Versus Not Using My Pin?
Purchases made with a pin have funds subtracted from your account instantly. Non-pin based transactions typically take 2 to 3 days to debit an account however that time can vary with respect to the merchant.
Dec 02, 2015 | Retail Supplies
What is the different of two phase and three phase
This sounds like a "homework" question, but the difference between "two" and "three" is 'ONE'.
The other difference is the "peak" voltage output (110V versus 220V)., because some appliances (stove, dryer) require a higher voltage.
Jul 06, 2011 | Computers & Internet
What type of power supply is required for this speaker system? If available, how much can I expect to spend for the power supply? I have the speakers but no power supply.
Check the power-connector on the speaker for the rating:
* AC versus DC
* 4.5 versus 5 versus 9 versus 12 versus 18 volts
* 0.5 versus 1.0 versus 1.5 amps
* pole-negative-ring-positive versus pole-positive-ring-negative
Try the local "Thrift Stores", once you have the specifications. You may get the correct suppy for less than $5.
Apr 20, 2011 | Harman Kardon HK595 Computer Speakers
So, i have a Tracker that has been changed, by the previous owner, from factory auto trans to a 5 speed. It has an issue with the engine (bogs) and the gauges (go haywire), when you run/ shift into gear....
Hi, the wiring is certainly different as the automatic has shift and TCC solenoids that the manual does not have. The safety interlock is also different--on the clutch pedal for manual versus the trans range sensor on the auto. Also, the backup light switch is separate on the manual versus integrated to the range switch on the auto. The speed sensor may be different or the same, I'm not sure. Now, the real difference in the drivability is that the auto trans is controlled by the PCM, and the data is fed back to the PCM for proper engine operation. If the previous owner didn't change the computer, then the algorithms in the computer are not optimized for a maunal transmission. I'm not sure that is the reason for your problems. Can you find out if the PCM in the car is the original versus a replacement for a manual transmission?
Jan 20, 2011 | 1998 Chevrolet Tracker
What is the difference between the LG WM2016 and the LG WM2010
The 2010 has a second rinse cycle, while the 2016 doesn't. Also the 2016 consumes a lil more electricity than the 2010 but thats probably because it's a lil bigger.
May 28, 2009 | LG WM2016C
Differences between the D-340L and the D-340R?
The Olympus D-340R is an updated model of the D-340L (which is no longer in production). They both have an SQ, HQ, and SHQ image quality setting, however, the D-340R has the additional ability to store an image file uncompressed in TIFF format. The D-340R also has the ability to magnify a portion of the image on the camera monitor LCD so that you can inspect the detail level of the picture. The D-340R includes a total of 8 MB of SmartMedia memory (either 2 - 4 meg or 1 - 8 meg card depending on the package) whereas the D-340L includes 4 meg. The LCD monitor is slightly smaller on the D-340R (1.8" versus 2.0"). The ISO rating is also slightly different (ISO 100/200 versus ISO 60/120) which allows a broader range of picture taking situations.
Aug 31, 2005 | Olympus Camedia D-360L Digital Camera
Aug 31, 2005 | Olympus D-320L Digital Camera
Sport & Outdoor - Others Logo
179 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
