Software V5.2 not loading. Loads as though everything is fine then lists number of issues help required
Load discs follow instruction on screen all goes fine wait while loading only at final step list of what could be problem contact Kodak representative, just frustrating just want machine to boot up and work
    Sergeant:
    Champion:
  • 285 Answers
Have you tried changing the hard drive
Posted on Jun 04, 2014
Enquiry
  • 152 Answers
SOURCE: boot up problem
i think you must have messed your pagefile settings... better use a windows CD and try fixing the boot.....
Posted on Feb 01, 2008
Pyrhyc
  • 2028 Answers
SOURCE: T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Posted on Aug 30, 2008
  • 104 Answers
SOURCE: My Acer Aspire 6930 will not boot to Vista just
u have to install a new windows.
Posted on Jun 09, 2009
haayz
  • 197 Answers
SOURCE: monitor does not work, computer starts up, dell
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Posted on Jul 01, 2009
  • 52 Answers
SOURCE: My Acer laptop will not load.
Try this, Acer told me to do this and it worked.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
My discs wont load
You could find the manual on the internet by google. Im afraid that it's possible that it possibly broke the disc drive or the part of the drive that automatically loads and ejects the disc.
May 17, 2012 | Nintendo Wii Console
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
Machine won't recoginze disc from program function
As I understand it, the Load button loads designs that you have prepared earlier and saved within the Designer 1, not disks made and saved in your Husqvarna software. These are the .DHV files (this might not be quite the correct file format name - can't remember!) you might see when you look at a disk in your software.
When in Program mode, you need to use the Menu button to go right back to the first D1 opening screen, then choose the Disk icon, navigate through all that to find your design, choose it and it appears on your Program screen. The second time you hit Menu from inside the program screen, you get taken directly to where you were the first time so it is quicker. But first time, it is a long slow process.
Jan 30, 2010 | Sewing Machines
Fallout 3 disc reading/load issues
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
Jan 27, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Two brand new games will not work on the Wii (the
We had the same issue this morning. you have to upgrade the Wii system menu. Look in the front page of the Super Mario Bros instruction bulletin and it tells you to do this. You have to be connected to the internet through your Wii though to do this, but our is now working. The download takes a few minutes but all is good. Hope this helps.
Just select the System Update option in Wii System Settings - just make sure your Wii is connected to the internet.
Dec 25, 2009 | Nintendo Wii Console
I want to set up a web cam to visit with friends over the internet
Noprob.
Setup disc. Follow instructions, should not need clicking, but then there all differant..
Once loaded, it may restart, once restarted and settled down, insert webcam usb, Poota should fined new hardware and load up your web cam.
After completing and tellking you your new appl is loaded and working.
fined icon on desktop or in your program list. Double click on icon.
Prog starts up, come up with 4inch white screen with a poss error screen? close error screen. you should be left with a white or dark empty square, with menu at the top.
Click on Devices/click your cam name, this will then start your webcam.
Rem, when clicking mirror in options your pic will be the other way round, just click back.
Hope this makes sense. Good Luck!
Nov 12, 2009 | HP Computers & Internet
Acer aspire not loading to windows
If you have recovery disc or back up disc put it in and restart the PC and start tapping the F12 key until at the Acer splash screen, you should get now see your boot order, now use your up and down cursor key to highlight the CD/DVD drive and then press enter, this will now start the recovery disc that you put in, just follow the on-screen instructions.
If you don't have a disc, restart the PC and at the Acer splash screen start tapping the ALT+F10 or just F10 and if you have a recovery partition on your hardrive then the recovery program will start up, just follow the on-screen instructions.
Thanks
Sep 09, 2009 | Acer Aspire T135 PC Desktop
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
Can u help me?
You may insert the Windows XP CD and reinstall Windows XP just to be sure. Follow the instructions on your screen and format the C Drive. Make sure you install all the required drivers to make everything work.
If you are optimistic follow the following instructions:
This will help you attempt to repair your system (and not via the Recovery Console).
Insert the Windows XP CD and follow the instructions on your screen.
Then after a certain point, you will be asked for three options --
1. Install Windows
2. Repair via Recovery Console
3. Some other option I don't recall.
Select the first option.
Then again, follow the instructions on your screen and again the computer will ask you three options.
This time select the second one -- Attempt to repair the computer (Press R).
This should start the automated repair process. This has been observed to work most of the time, but in a few rare cases it doesn't work. So I suggest you try it if you have the patience. ;-)
Good Luck.
Oct 13, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
