Question about Samsung Computers & Internet
How to connect a 27" MONEX M27QSM 2560x1440 QHD Monitor to a SONY E SeriesWhat Laptop
What kind of connection is required to hook up the 27" monex M27QSM 2560x1440 QHD samsung PSL computer monitor to a SONY E Series Laptop Windows 7
SOURCE: trying to connect samsung 2253 bw lcd monitor to new computer
changed connections
Posted on Aug 24, 2008
freetek
  • 5568 Answers
SOURCE: Lcd monitor 20.1
The white screen is caused by a total lack of control over all pixels. The opposite effect; all black, happens when a failure turns all pixels on, blocking all but a small amount of light.
This could have more than one source; one output of the power supply has failed so the logic section no longer is receiving supply voltage or an external source has damaged the video input of the monitor. The backlight responsible for the white screen is obviously working as this is a separate power supply output to an inverter that powers the backlight lamp.  I'm afraid this is not a DIY repair.
Posted on Sep 18, 2008
  • 64 Answers
SOURCE: My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Posted on Sep 22, 2009
  • 201 Answers
SOURCE: Acer T230 H monitor Hdmi ConnectionProblem
I don't think your doing nothing wrong, but I may be wrong. I would just stick with the other connections. HOpe this helps!?
Please rate solution - Thanks.
Posted on May 14, 2010
  • 22 Answers
SOURCE: connect flatscreen tv,cable/dvr box and dvd player
try a banana
Posted on Jan 04, 2011
Pixelated appearance
Hello Anon, it seems you may be looking at a driver conflict here. Setting up this project is easy; bring in a second monitor and prepare to swap between the two frequently.
1. On the Eizo's menu initiate the self calibration.
2. When the Eizo completes the self calibration and the Pixelation persists, uninstall all the Graphic Card drivers on your computer.
3. Install the manufacturer's specific graphics card drivers from the manufacturers website.
4. If the monitor continues to be pixelated then ensure that your GC is 4k ready. (That it can natively display 2560x1440 @ 16:9 aspect ratio).
I suspect your Graphics Card is not up to par, it likely has full 1080 but not enough to push 4k as your monitor natively runs. Purchase any GC with a 4k ready capacity and you will enjoy the full beauty of your purchase.
Source:
http://www.tomshardware.com/forum/304706-33-completely-uninstall-graphics-drivers-install-ones
http://en.wikipedia.org/wiki/Graphics_display_resolution
http://www.eizo.se/default.aspx?page=11&product=CG277-BK
Mar 06, 2015 | Eizo Nanao Eizo - CG277-BK 27"" Wide...
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Hooking up sony tv to HP laptop
Do you have a HDMI jack on your TV? it looks just like the blue/graphics/monitor jack on your laptop. If so use it to connect and you should be able to use your tv as a monitor. (if you tv came with the HDMI cable?, if not you can purchase one ez enough from Radio Shack)
Check your users manual for directions on how to use the remote to get it to that function. My Hansphree TV I have to put it on AUX to use my laptop hooked to it and see my TV as my lappy monitor.
Hope this helps you and others! Good Luck.
Feb 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Vgn-fs730
Get an old monitor CRT or LCD. Connect this to the back of your laptop to the appropriate connection. Turn on this monitor and your laptop. Now on your laptops keyboard are some blue highlighted keys called function keys. Press and hold the one marked "Fn" and then press the F7 key (on my Sony - yours may be different but the key with a small blue rectangle with LCD inside a foward slash to what looks like an oval with square sides) this is the external monitor key. If the external monitor comes on with the laptops screen information then your mercury lamp in the laptops screen has died. Then a reputable repairman can replace your screen and lamp for $200. - $300. If nothing appears on the screen then most likely the video chip in your laptop has died. Replacing this will require a new motherboard for the laptop. You should contact Sony about price and any extended warranties they may have,
Jan 13, 2009 | Sony VAIO VGN-S460 Notebook
Vpl-es4 sony projector-frequency out of range
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
Sep 26, 2008 | Sony VPL-ES4 Projector
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Computers & Internet Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
