Question about Dirt Devil SwivelGlide Bagged Upright Vacuum
SUCTION IN THE WRONG PLACE
THIS MODEL HAS A U SHAPED BAG LOCATED IN THE HANDLE HOUSING. ALSO INSIDE THIS HOUSING IS A FILTER DIRECTLY OVER THE MOTOR. THE SUCTION IS STRONG BUT IT DOESN'T GO UP THE HOSE TO THE BAG, IT GOES DOWN THROUGH THE FILTER OPENING TO THE MOTOR. THERE SEEMS TO BE NO WAY TO GET THE SUCTION TO WHERE IT BELONGS UP THE HOSE TO THE BAG.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: "brush bar spins erratically"
Belt needs to be replaced, it has stretched to the point that under load, it won't turn the brush roll like it should, so I would advise replacing the belt. And while you are doing that, check the brush roll and make sure the ends turn freely, if not, then replace it also. Then check the dirt inlet while you have the brush roll out.
Posted on Feb 29, 2008
  • 126 Answers
SOURCE: Vacuum Problem
The Bissell can have several filters in it, depending on the model. Some have a round hepa filter that is covered with a foam sleeve. This filter is located at the bottom of the dirt cup. Others have a foam filter that is located under the dirt cup in a pull out drawer. Also, they can have a cylindrical separator above the dirt cup which can be removed and washed. They are usually a blue plastic and you reach in and turn it a 1/4 turn counter-clockwise to remove. If your machine has the hepa filter, when you remove the dirt cup, the filter is at the bottom and you turn the bottom 1/4 turn and the clear housing will come off to access the filter. You should also check the small filter on the machine just below where the cup sits. This will only be there if your machine has the hepa filter on it.
Posted on Mar 21, 2008
  • 82 Answers
SOURCE: lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Posted on Apr 28, 2009
galati2k
  • 281 Answers
SOURCE: No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Posted on Jul 02, 2009
NO SUCTION
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Aug 08, 2017 | Dirt Devil SwivelGlide Bagged Upright...
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
My Oreck XL vacuum does not have enough suction to pick up dirt. Any suggestions to remedy this problem? The belt is strong, the bag is not full, and there do not seem to be any obstructions.
Turn the machine on and be sure the bag expands quickly and fully like a balloon. If the bag does not fill with air, or is soft, there is probably an obstruction inside the handle tube or fan housing. Disassemble the handle to check for blockage, or remove the bottom plate to check the inlet to the motor fan.
Jan 19, 2011 | Oreck XL Ultra Bagged Upright Vacuum
All fo a sudden, no suction, motor runs fine, no clogged tubing.
Be sure the upper attachment hose is inserted firmly into the lower hose into the nozzle. Check for suction at the end of the hose, and if there is no suction there must be an obstruction in the hose, or the filter inside the bag compartment is plugged. Be sure the brush is turning when the handle is released.
Jan 18, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Feb 22, 2010 | Kenmore 31913 Progressive Direct Drive...
Electrolux 1572E (Discovery II) How to remove suction motor cover?
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Aug 10, 2009 | Electrolux Vacuums
Dirt Devil SwivelGlide Bagged Upright Vacuum Logo
19 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
