Question about Ricoh Office Equipment & Supplies
How to enter sp modes in nashuatec 3713 - Ricoh Office Equipment & Supplies
  • Ricoh Master
  • 3,320 Answers
What is the solution for a Ricoh MP 6001 which is not entering in sp mode?
The manuals are here on how to change that: http://www.ricoh-usa.com/products/product_details.aspx?cid=2&scid=3&pid=2318
Jun 16, 2014 | Ricoh Aficio Office Equipment & Supplies
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
Comment entre en mode sp
Hello!
Next time put your question in English, please!
To enter SP mode you need to follow this steps:
Press yellow key.
Enter 107 in the key pad.
Press red key for 3 sec.
And you are in SP mode.
Jul 12, 2011 | Ricoh Office Equipment & Supplies
I have a copier / printer Nashuatec Aficio dsm651. Everything works fine but when I print A3 meter marks my one and not two. The person who has it porata explained to me how to get in 'SP MODE machine...
Hi, in order to activate the double count for A3 paper, you have to go into "special" SP mode. The procedure is almost the same as going into regular SP mode, but as you hit "Copy SP" on the touch screen, make sure you are holding down the pound (#) key. Then you should be able to find 5104.
You can only change 5104 once, so one you enable it you won't be able to change it back to counting larger paper as 1 click instead of 2.
Apr 27, 2010 | Ricoh Aficio 450 Copier
Nashuatec 2205 ATICIO problem SC 542
nashuatec 2205 equivalent to ricoh 1022/220 and the problem of sc542 means that you termistor is out of order. Don't panic,with little patient you could solve it.
Firstly,switch off the machine, then take out the fuser unit after you open the lateral door. Below the unit,you will see 2 termistor unit with red contact.Replaced it both with new unit.Reinsrt it the fuser unit back and closed the lateral door.
Switch on the copier, you must go in sp mode . First
push the yellow[c] button follow by button1,0,7 then
push red button[cancel] for several seconds until you in sp mode revealed by the screen.Switch off the copier for 1-2 minutes then switch it on,wa la it working back. It will cost you compare to calling the technician
Apr 15, 2010 | Ricoh 6513 Copier
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Copier code error
service program sp-9, mode 90 needs to be set to "0"(off). also, the key counter shorting connector must be removed.
that should disable any key counters.
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
