Question about Denso 1991 GMC K1500 Sierra XC 4.3L Remanufactured Alternator
Why does my truck stall when I plug in the map sensor
Timing and such are good, ran clean prior to total shut down.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sensor is bad and it is giving the wrong fuel/air mixture info to the computer.
Posted on May 29, 2014
2003 sonoma shuts down when MAP sensor is plugged in
Could be a bad one even if its new it happens
Feb 25, 2014 | 2003 GMC Sonoma
1991 chevy c1500 stalling
Usually a problem with a dirty throttle body or a faulty idle air control valve. The computer controls idle speed by regulating how much air enters the intake thru the valve.
Oct 13, 2012 | 1991 Chevrolet C1500
92 jeep wrangler 4 cyl 5 speed skipping and bogging down idling rough replaced fuel pump/filter injector o rings fuel pressure regulator timing chain distributor plugs wires map sensor crank sensor idle...
Have you checked the cam sensor? Also does that vehicle have a "throttle position sensor"? Some cars use both MAP and MAF sensors, not sure about your particular vehicle but if it is one of those, cleaning the MAF wouldn't hurt. Good luck.
Jun 28, 2012 | Cars & Trucks
1996 jeep cherokee stalls, I've replaced the throttle position sensor, MAP sensor, and carbeurotor. What else could it be?
You replace sparkplugs,plug wire,tps,map,cap and rotor.Thats good,If the vehicle runs and you come to a stop and it stalls,That is the IAC (Idle air control) you say it ran fine for a week now its acting up, Service the IAC or get it replaced.
Mar 21, 2012 | 1996 Jeep Grand Cherokee
1995 Subaru Legacy stalling when going down the road
check fuel pressure should be 36 - 43 psi sound like problem could be fuel pump, first what i would do change fuel filter,replaced fuel pump relay check fuel pump fuse make sure it is in place tight. code scan car if you see check engine light flash.another thing cause stalling contaminated gasoline.
Nov 20, 2011 | 1995 Subaru Legacy
I have a 98 Electraglide Classic. The problem I am having is intermittent. While riding my ignition system will shut down, no rough running or missing, just total stall. Most of the time it will start back...
Hi Sparkypickle, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day. Harley Check Engine Lamp Diagnostics
Aug 24, 2011 | Harley Davidson FLHTC - FLHTCI Electra...
85 Citation stalls at idle after reaching operating temp
Are you sure this has a carburetor? By 85 most were fuel injected. Did you check the gap on the plugs? Clean the threads and seat? Map sensor maybe bad.
Sep 30, 2017 | 1985 Chevrolet Citation
My engine shuts off while I am driving and then takes about 20 minutes before it will start back up. It also will start up and then shut off before I can get moving. Finally when I am driving sometime it...
the very 1st thing for you to do is have the OBD 2 electronic engine control system tested for trouble codes, whenever you have a stall like this there is almost always a code that is stored for the problem, which in your case will most likely be a crankshaft position sensor, but do the test.
Oct 01, 2009 | 2001 Pontiac Grand Am SE
Denso 1991 GMC K1500 Sierra XC 4.3L Remanufactured Alternator Logo
26 people viewed this question
Top Denso Electrical Supplies Experts
Jude24
Lawrence Oravetz
Stan Ford
Are you a Denso Electrical Supply Expert? Answer questions, earn points and help others
