Question about Dirt Devil SwivelGlide Bagged Upright Vacuum
NO SUCTION THIS MODEL USES A U SHAPED DISPOSABLE BAG. THERE IS NO SUCTION GOING UP THE LONG HOSE TO THE BAG. THE SUCTION IS STRONG BUT ITS GOING DOWN THROUGH THE INSIDE FILTER. I HAVE CLEANED EVERYTHING TO GET OUT ANY CLOGS BUT NOTHING WORKS. THE SUCTION GOES DOWN THROUGH THE FILTER AND NOT UP THROUGH THE HOSE AND THERE DOESN'T SEEM TO BE ANY CONNECTION BETWEEN THE TWO.THE SUCTION IS IN THE WRONG PLACE?
    Sergeant:
    Champion:
  • Dirt Devil Expert
  • 357 Answers
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Posted on Aug 08, 2017
  • 298 Answers
SOURCE: Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Posted on Nov 18, 2007
reddevil6
  • 1673 Answers
SOURCE: Poor suction
Check the inlet down by the brush roll, make sure it is open, if it is then the hose itself must have a clog. If the hose comes off, drop something like a marble in one end and see it it comes out the other end, if it doesn't then you have a clog.
Posted on Jan 10, 2008
reddevil6
  • 1673 Answers
SOURCE: "brush bar spins erratically"
Belt needs to be replaced, it has stretched to the point that under load, it won't turn the brush roll like it should, so I would advise replacing the belt. And while you are doing that, check the brush roll and make sure the ends turn freely, if not, then replace it also. Then check the dirt inlet while you have the brush roll out.
Posted on Feb 29, 2008
worldvet
  • 859 Answers
SOURCE: Dirt Devil M086700 Wide Glide upright suction problem
These new fangled Hepa filters get clogged up pretty easy and when there's no place for an outlet of air there is no suction going into the clear basket.
You're right. Best way to clean these things is to bang them upside down outside on some concrete or another hard surface until there is no more dust coming out. You can replace them and eventually it comes to that.
The hose that leads up from the suction bed housing has a tight turn in the bottom area and this can collect something large that then collects smaller and smaller. The hose can be disconnected from the bottom unit and it may take a straightened coat hanger to clear out whatever may or may not be in there.
To be sure you have a tight seal just see that the plastic can is seated firmly at the bottom and the top locks in place. The gasket does its job once there is good airflow and the vacuum will do the rest.
Any questions or need for clarification just comment back to me below and I'll get back to you as soon as I can.
Regards,
Worldvet
Posted on Jun 10, 2008
  • 109 Answers
SOURCE: Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Posted on Aug 23, 2009
Vacuum is not picking up anything
If you remove the hose from the vacuum, what is the airflow strength when the machine is turned on? (airflow = suction).
If it is strong then the problem is most likely a blockage in the hose, wand or floor tool.
If it is not strong then the problem is most likely internal. Check that canister and/or dust collection bag is not full, and that there is no blockage in the bag connector. If these are all okay, then you will to take your machine to a service/repair agent.
Dec 26, 2016 | Vacuums
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Vaccumn repair ...lostlosing suction, belt still turning roller bar, hose clear
To generate strong suction, the motor has to turn at a good speed.If its a bag vacuum change bag with new one when a great deal of debris builds up in the vacuum bag, the air faces greater resistance on its way out.
Sep 12, 2009 | Vacuums
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Dirt Devil SwivelGlide Bagged Upright Vacuum Logo
24 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
