Question about Cobra Radio Communications
Cobra CXT195 walkie talkies wont charge - Cobra Radio Communications
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
Posted on Jul 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: New walkie talkies wont stay charged and wont
It's really hard to tell what's going on without more information, but it sounds like your two problems are really one; that is, the shutdown is due to low battery power. If you have a voltmeter you can check the charger output and the battery voltage when fully charged. My bet is that the batteries are no good, so they are not taking a full charge and are discharging rapidly. Try new batteries in one of the radios and see if that solves the problem.
Posted on Dec 29, 2009
BillB-SA
  • 2761 Answers
SOURCE: we have lost manual for cobra microtalk walkie
I couldn't locate your specific model, but all of the Microtalk series radios seem to be basically the same as far as operations. Follow the link below to a manual that you can download/print -- it should work fine with your radios:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Bill B
Posted on Apr 18, 2010
micromatikal
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
Posted on Oct 12, 2010
eradiostore
  • 1654 Answers
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
My Cobra MircroTalk walkie-talkies aren't charging. The charge light doesn't turn on and I've made sure u turned Tue units themselves off. The model number is: GA-CQ
If your problem started after replacing the batteries (mine did), see this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html If that is your problem, you can also fix it by wrapping foil around the bottom of the battery that makes that touches the bottom side charging contact.
Oct 19, 2013 | Radio Communications
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
New walkie talkies wont stay charged and wont communicate with each othe. One calls and then goes blank and turns off,
Dec 29, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Jul 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Charging Problem
You can ask the seller you bought the walkie talkie from.
Sorry, I don't speak English very well.
Dec 25, 2008 | Cobra Radio Communications
Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Sep 21, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Radio Communications Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
