Question about Vehicle Parts & Accessories
Timing belt on magna tw vrx
What is involved in replacing timing belt on magna tw vrx
  • 1,511 Answers
More than you care to do unless you are a shop. Takes weeks to complete the task and in the end you wish it never happened.
Posted on May 09, 2014
Power steering belt snapped.I have a diagram on the belt path around the steering pump etc, just need someone explain what I need to do to ease the tension so I can put on the new power steering belt?
I am not familiar with the set up on the Magna for tensioning the serpentine belt. Normally there is a tensioner pulley fitted to the engine which has to be moved a little by applying opposite pressure with a tube spanner or ring spanner to release tension on the belt so it may be slipped off and then moved back into position again when refitting. That is probably what you have also.
I suggest you check with the guys on the Magna owners Forum in the link below. They will be able to tell you what to do on that Mitsubishi Magna engine. Indicate when asking which engine you have fitted in your car.
http://www.aussiemagna.com/forums/forumdisplay.php?f=10&s=f60d4f8f450239c05ab7fb60a8604f39?s=f60d4f8f450239c05ab7fb60a8604f39
Jan 14, 2016 | Cars & Trucks
I have a 2005 vrx magna and have oil on front passager floor how would it be leaking in there
A/c has oil in it Only about 2 to 4 ounces). It would come the evaporator in the dash.
Jul 24, 2015 | Cars & Trucks
Where is the relay switch on my magna vrx?
It could be a faulty dip switch on steering column. To eliminate this connect the correct wires (check wiring diagram first before for colour coding). If the low beam works with connected wires,switch is faulty.
Aug 21, 2014 | Cars & Trucks
I need a picture of the serpentine belt so i can replace it also the power steering belt for a mistsubishi magna 97 3.0 V6
Do you still need a photo of serpentine belt for your Magna - I just had mine fall off and had to work it out myself - can give you a photo if it helps you
Jan 17, 2010 | 1997 Mitsubishi Eclipse
What colour wires go to what speakers and stuff on a magna tj vrx
get the wiring diagram if they are factory speakers from a Haynes book if it is a new deck get a wire diagram from best buy
Dec 29, 2009 | Car Audio & Video
Just replaced timing belt on TE magna vehicle now running rough, how do you set base idle,
weep_wail@yahoo.com.sg did you replace both the timing belts? this car has an A belt and a B belt (B is for the balance shaft) email me
Oct 08, 2009 | 1996 Mitsubishi Galant
Can i replace the timing chain tensioner without
you don't have to remove the head to do the timing tension er but will have to do the belt! just get a book and line up the timing marks before you take it apart! good luck
Sep 18, 2009 | Mitsubishi Pickup Cars & Trucks
Replace timing belt in 2002 Mitsubishi Magna
Haynes Manual is probably the best solution for you.
Aug 24, 2009 | Mitsubishi Passenger Cars & Trucks
Te magna waterpump changeover
MAGNA 1996 TE you have to pull down all covers of front of motor remove rh wheel and inner plastic protecters to access crank wheel remove crank wheel. rh engine mount and two outer belts lower/lift engine to remove timing belt pulleys ect.remove timing belt to access waterpump lots of labour can email photos if any one needs an idea .of whats involved when replacing water pump. best get a timing belt kit and replace belt ,pulleys as well. then good for 100.0000 kms and plugs as well platium ones by doing on your own can save 800 to 1000 dollars just be carful not to move pulleys on timing belt . good luck i posted this after i had no response .a desiel mechanic guided me though the ordeal a lot of labour for a waterpump it took me 8 hrs straight to do . hope this is useful i didnt need timing kit just belt total cost if you do job $350.00 i got quoted $1500 by mechanic
$25 COOLANT
$300 TIMING BELT KIT OR $100 FOR BELT ALONE
$95( WATER PUMP NON GEN SUPERCHEAP AUTO)( GENUINE MITS $300 TOO MUCH$$$)
$90 PLUGS PLATIUM
$30 OIL
$7 OIL FILTER
$10 GASKET GLUE
Apr 01, 2009 | Mitsubishi Diamante Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
