Question about Sony Televison & Video
I need the table base/stand for plasma Sony KZ 32TS1U
  • Sony Master
  • 1,511 Answers
Try the eBay method.
Posted on May 09, 2014
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Tv plasma sony KZ-32TS1U problems of turned on /
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Nov 10, 2011
Looking for table top stand for Sony LED TV
Just try by any authorized dealers for Sony. If not available, check www.alibaba.com
Nov 27, 2013 | Televison & Video
I need a replacementnbase stand for a sony wega 42" plasma tv
Contact Sony with the model number to see if available or not, other than that Google the model number with base to see what comes up, last resort might be to look on EBAY.
Dec 10, 2012 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
I need a table stand for my sony TV model KE-P42M1
Contact the authorized dealer for Sony at your town.
Dec 01, 2012 | Sony KE-P42M1 42 in. Plasma Television
Please can you help! I need a table top stand/base for a 37" flat screen Alba television - where can I buy one ?
Tries websites like Shopjimmy.com,Amazon.com,Ebay.com to buy many of the LCD and Plasma tvs base stands and wall mounts.
Oct 28, 2010 | Televison & Video
Philips 42 PF7220A Table top stand is needed
310430816731 or 3113912877791 ; from encompassparts.com ; guest login. 34.00 -50.00
May 03, 2010 | Philips 42PF7220A 42 in. Plasma Television
I need a table top tv stand for my sony kdl 40w3000. perhaps you mounted your screen on the wall and so do not need your old tv stand? please get in touch! i have the money ready!
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
Feb 04, 2010 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Samsung 4235X/XAA older Plasma TV Need to take the base out for m
GENTILITY lay that set face down on a table covered with a thick blanket. There should be 4 long threaded bolts near the bottom that fasten the legs of the stand inside the framework of the set.. Remove these and the stand should slide right out.
www.mcveyelectronics.com
Apr 11, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Need a base stand for Sony KE37XS910 Plasma.
X-4042-206-3 is the part number.. only place i found it was at encompassparts.com.. your part is no longer available but this is the sub part..
Mar 14, 2009 | Sony Televison & Video
Tv turns itself off and on.
I just had this problem. The plastic back of the TV has a grated opening directly in the middle and towards the top of the TV. There is a fan directly behind. The grated opening was full of dust so air couldn't pass easily. I simply vacuumed the dust. I went the extra step and removed the whole back of the TV and vacuumed the entire space.
I assume the internal temperature exceeded its maximum so the TV turned it self off. Cooled enough to try a restart, heated up, ...
Oct 02, 2008 | Sony WEGA KZ-32TS1 32 in. Television
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
