Used a cd/dvd cleaning disc to clean e: drive lens now e drive won't read cd or dvd
  • 1,511 Answers
Should not have done that. The alignment is out of sync.
Posted on May 09, 2014
Drawsalot
  • 38 Answers
SOURCE: do not read the cd or dvd disc.
Two possibilities that are immediately apparent. One, the lens on the drive is dirty. Stop by a department store and buy a CD/DVD laser lens cleaner CD and put it in the drive several times, making sure that it tries to read it each time. This can brush away the debris on the lens and it may work again. Two, the drive motor or lens assembly (that moves) has failed. My experience is that these drives have a 2-3 year life span. Luckily, they are now bargain-priced and you can pick them up at your local discount store and replace them yourself.
Posted on Nov 12, 2007
  • 3 Answers
SOURCE: CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Posted on Jan 24, 2008
hardkiss69
  • 43 Answers
SOURCE: Optiarc DVD RW AD-5540A (Code 39) Device Driver may be missing or corrupted
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
  • 4 Answers
SOURCE: CD ROM ONLY READS CERTAIN DISCS
uninstall the drivers on cd rom.then restart the pc the pc will reinstall them
Posted on Jan 11, 2009
preachw996
  • 1179 Answers
SOURCE: DVD/CD-ROM Drive just stopped reading all discs
Have you tried using a good quality dvd cleaner? Alot of times a dirty laser will cause this problem. After cleaning try using a known good dvd and see if it works. If not check your device manager to see if the drive is functioning properly. If there is a yellow ! then the drive either has a corrupt driver or it has died. You can replace it fairly cheap as a dvd/cd burner can be replaced for around $45 max. Hope this helps.
Posted on Jul 11, 2009
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
My LG DVD Writer is not reading any disk when i am inserting the disk in Drive. IT stops blinking also.
Hello Ammit,
It seems that the lens of the DVD writer is not working properly. Please try to clean the lens of the DVD writer with help of CD/DVD lens cleaner disc. The lens cleaner disc is easily available in market. After cleaning the lens try to run the CD/DVD again
May 08, 2011 | LG (GSA-H42NK) Burner
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    OUr DVD player has is unable to read the inserted disc
    Try cleaning the laser lens. There are specialized cleaning discs available for this purpose. If the debris is too much for the cleaning disc, the lens may be cleaned with a photographic quality lens cleaning solution and proper photographic quality brush. The lens assembly is quite fragile, so use only enough solution to slightly wet the brush and be very, very gentle when performing this operation.
    Oct 04, 2009 | Panasonic Televison & Video
    Readable DVD's but not CD's
    That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
    Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
    Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
    Optiarc dvd+-rw ad7580s can't read cd's only dvd's
    Please use a lens cleaning kit to clean the lens inside the disc drive itself. The drive reads dvd's and cd's at different speeds so a dirty lens could read one but not the other.
    Sep 07, 2009 | Dell Inspiron 1545 Notebook
    Player shows '' No Disc'' even when inserted with a disk
    When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
    Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
    See also the following websites on how to clean the lens, use a cleaner disk first:
    Gizmo Highway DIY - Clean your CD player lens
    Lens Cleaning CDR CD-RW (how?)
    DVD Not Working
    Mar 04, 2009 | Sony Televison & Video
    PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
    When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
    Try first using a lens cleaner disk, like the ones here.
    If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
    How to Clean the Laser Pickup Lens on your DVD Player
    How to safely clean a DVD lens?
    Clean DVD lens, or replace player?
    Clean CD or DVD ROM lens with a brush?
    Cleaning your DVD drive
    How to clean a DVD player
    How do I clean my DVD player optical lens isoproponol alcohol
    Feb 10, 2009 | Televison & Video
    Will not read DVD discs.
    It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
    A dirty lens can read CD but not DVD.
    Tru first using a lens cleaner like this ones:
    If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
    If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
    You can order the lens pickup from factory and replace it.
    Sep 02, 2008 | LG Computers & Internet
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
