Question about Samsung Washing Machines
Samsung washer b1245s HE2 error
Error HE2 shows on he screen, 10 min after the washing has started.what do I do about it to fix the problem? thanks
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
SOURCE: samsung smart wash B1245S SE error
you need to drain the washing machine by removing the little door below the drum door and pll out the the hose with a white knob (beware alot of water comes out so have a couple of pans ready. the fault means that there may be a blockage in the debris filter (next to the outlet hose yuo just pulled out) am sure you have prob already discovered the fix by now though!
Posted on Apr 28, 2009
vickygomar
  • 460 Answers
SOURCE: HE2-plus washer will not start. error, status light shows "F-24"
code F24
WATER TEMPERATURE SENSOR ERROR
sorry but the following information is for TECHNITION SERVICE(only)
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
"Was this helpful?"
Posted on May 12, 2009
milten1
  • 1304 Answers
SOURCE: samsung washing machine b1245s makes a grinding
i would grab a towel and check the pump for grit
and things that dont belong
may not be the actual problem but thats whered id start
have a great day
Posted on Oct 09, 2009
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Dec 17, 2010 | Samsung Washing Machines
Samsung washing machine b1245s makes a grinding noise but wont spin...any ideas why and how to fix the problem?
have a great day
Oct 09, 2009 | Samsung B1245 Front Load Washer
Samsung b1245s washing machine
May 07, 2008 | Samsung WF337AA Front Load Washer
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
