Question about Sunbeam Model T20B Automatic Toaster Pristine
How can I fix the thermostat unit on a Sunbeam T20B?
I have a Sunbeam T20B. Everything works fine but it stops toasting prematurely. I've adjusted the Light/Dark screw all the way in & out and there's really no difference. Is it my thermostat unit? I've got it out of the toaster body now and am wondering if there's really much I can do with it. Can refurbished units be purchased? Thanks!
5 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Posted on Apr 03, 2009
Asbestos 56
  • 191 Answers
SOURCE: Sunbeam T20 toaster. Vintage. this
A good resource for vintage toasters is http://www.toastercentral.com/
Posted on Jun 23, 2011
mc1bean
  • 3053 Answers
SOURCE: I thought I had fixed
Hello, las
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
mc1bean
  • 3053 Answers
SOURCE: I have a sunbeam radiant
Hello, home
Thanks, Mike
Sunbeam vt40
Adjust the screw on the bottom which adjusts the tension created by the heaters. If this doesn't work, "bump" it some to dislodge crumbs that may be inferfering with the trip lever for the thermostat.
If nothing works, try kitchenmade usa or toaster central who both work on and fix vintage toasters.
Frank@kitchenmadeusa.com
Jan 06, 2013 | Sunbeam Kitchen Appliances - Others
I thought I had fixed my sunbeam toaster but it is not working. Originally It had not been used for years. It was put away working normal. When I pulled it out of storage, I cleaned it and it no longer...
Hello, las
Thanks, Mike
Aug 24, 2011 | Sunbeam 3806 Classic Chrome 2-Slice...
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
Frididaire fridge mod.#FRT21IL5DBA 4 1/2 yrs old. In outside storage room of carport. Stopped running after stretch of low 20's temps. in winter of 2009 Unplugged it, checked coils. Plugged it in when...
Well it should be fine when it warms up, these are not designed to run in anything below 60 degrees, when the temp gets too low it confuses the thermostat and it shuts everything off, as long as the room is above 60 should work fine.
Sean
Mar 30, 2011 | Frigidaire Refrigerators
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the cooling! fan runs ok. Have got it half pulled to bits...problem seems to be in the cooling motor/...
Apprently this unit is unrepairable. I rang Sunbeam and it has a two year warrenty. I suggest you give them a call too as they were very help full to me.
Nov 22, 2009 | Sunbeam Computers & Internet
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Toaster malfunction
try adjusting the screw on the bottom of the toaster
Sep 09, 2008 | Sunbeam Kitchen Appliances - Others
Sunbeam Model T20B Automatic Toaster Pristine Logo
49 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
