What type of power steering fluid for 91 toyota tercel
  • 1,511 Answers
Have it looked up at the parts shop near you.
Posted on May 09, 2014
How do you add power steering pump to 95 toyota tercel
Do you need to replace an existing pump or is your car currently manual steering? If it is manual steering there will be more than just adding a pump. The actual steering rack is most likely different from a power steering unit so there would be multiple components required to convert. If your pump is faulty, you just need to disconnect the lines, remove the belt then remove the pump and install the new one. While you are doing that I would flush the old fluid out of the rack to increase life span of steering rack.
Jul 25, 2015 | Toyota Cars & Trucks
1995 toyota tercel. Steering wheel is hard to turn and i dont see where i can put power steering fluid
Are you sure it has power steering? Many tercels did not. Without PS, the steering wheel will be more difficult to turn when standing still.
I had a '94 Tercel few years back, and it had no PS.
Mar 10, 2015 | Toyota Cars & Trucks
Starter won't engage
I would guess the steering fluid has gummed up your solenoid, making it difficult for your starter to engage the solenoid.
Mar 15, 2014 | 1991 Toyota Pickup
Where does the power steering fluid go on my 1993 Toyota Tercel?
Should be a tank on the side of the fender with a hose going to the pump.
Sep 30, 2012 | 1993 Toyota Tercel
When I am stopped at a red light, drive thru, etc. car tries to take off even while clutch is depressed. 91' Toyota Tercel 4 sp tranny
Does the clutch pedal feel any harder or softer than ussual?it could be the clutch and pressure plate are worn or hopefully just that the master or slave cylinder is leaking.The master cylinder is under the hood opposite side to the steering wheel and slave cylinder at the gearbox
Aug 01, 2009 | 1991 Toyota Tercel
Type of power steering fluid for 2001 toyota camry
Power steering fluid - Dexron 2 or 3 automatic transmission fluid. Yes transmission fluid. And while you are at it check the fluid level in the transmission.
Since you got the hood up, check the brake fluid, wiper fluid, radiator fluid, battery fluid, oil level.
Apr 26, 2009 | 2001 Toyota Camry
I do not know where to put my steering fluid
does it have power steering ??chances are it doesnt if you cant find a resevoir
Dec 19, 2008 | 1992 Toyota Tercel
Location of power steeringreservoir '95 toyota tercel
Why do u need to locate reservoir. what is the actual problem
Nov 24, 2008 | 1995 Toyota Tercel
Headlight/Turn Signal/Wiper Switch Replace
The turn signal switch requires the steering wheel to be removed, you can borrow a steering wheel puller from most any chain parts store like Kragen or Auto Zone to name a few, always disconnect the battery before starting work, also if you have an airbag on the steering wheel you MUST disarm the system before starting work or serious injury can result if it fires. The screws that retain the airbag or horn pad if present will be on the back side of the steering wheel in wells, about an inch deep, most likely they are #2 Phillips.
Oct 07, 2008 | 1991 Toyota Tercel
Power Steering fluid: Put it where, now?
just follow the pipes from either the pump, or the pipes from the rack eventually you will run into it from memory i think it is bolted to the firewall up high on the right as you look at the car.
Jun 21, 2008 | 1992 Toyota Tercel
Computers & Internet Logo
David Payne
David Payne
