Question about Dryers
Hi there please help my hotpoint dryer is working and now i see a bright red light now and again at back of drum. why is this i have cleaned it out and brought a new vented pipe please why is this happening sacred in case it catches fire?
    Habit-Forming:
  • 144 Answers
It the heater coil. If this is a old dryer this is normal. It should cycle on and off.
Posted on May 10, 2014
docjohn174
  • 943 Answers
SOURCE: Maytag MDG16CSBWW heating problem
HI thanks for the question. well ,you changed all the parts you needed to. but clean the venting from back, to the outside. thanks. please rate my answer. thanks.
Posted on Oct 11, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: hotpoint tumble dryer is making
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Posted on Feb 14, 2009
  • 574 Answers
SOURCE: My dryer drum is rotating and the heater is
Can you feel air blowing out the vent on the dryer itself? The reason I ask is if you dont feel any air blowing out your blower fan isnt working and wouldn't matter if vent was clear if you dont have any air movement.
Posted on Jan 23, 2010
Testimonial: "A very helpful suggestion, thanks. Clothes aren't moving as they should be, confirming your diagnosis. Thanks for your fast and concise help."
hunter19_46m
  • 7482 Answers
SOURCE: my tumble dryer is overheating.
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Posted on Apr 14, 2011
My hotpoint TDC30 dryer is cutting out after 3 mins ,the drum is warm inside and wont restart till its cold inside the drum
Hi joanne balla...
Sounds like the cyclic thermostat, thermostat, fuse (differnet names for the same part)..is faulty...replace it.
You will have to remove the back from the machine, look for the air tube going to the vent of your dryer and located on it will be the thermostat/s.
To test it, remove the wires fromthe two terminals and tape them together, then try running your dryer again and if it runs and heats ok then replace the cyclic thermostat/fuse.
Go to the following webpage to see the thermostat
Please take time to rate me
http://www.espares.co.uk/parts/tumble-dryers/thermostats/hotpoint/p/1587/808
Sep 13, 2011 | Hotpoint Dryers
Water wont empty after wash alarm keeps buzzing and red light shows a picture of a tap
Please check if there is any block in the water outlet pipe. after cleaning the outlet pipe, you can switch off the machine for an hour or so. and then again switch it on. This may help. Please get back to us if any more help is needed.
Regards
Sweet Rascal
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Tumble dryer makes whine noise but doesnt spin
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
Where do I find the heating element in my hotpoint dryer
Heating element is behind the drum. Disconnect power. Use putty knife to release 2 spring clips holding top at front edge of dryer. Swing top back. Remove two screws holding dryer front to sides near open top. Swing dryer front to the side. (you don't have to disconnect the door switch wires) Remove plastic tub block at top center of opening. Release belt. Pull up on back of drum, then pull drum out through the open front of dryer.
Sep 12, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
