Question about Coffee Makers & Espresso Machines
I got a Krups Crematic F874 recently that has been
I got a Krups Crematic F874 recently that has been pre-loved many times. Limescale wrecked the tube for water going into boiler for espresso so it's pure leakage. It's about 4 inches long. Where on earth do I get a replacement from? I live in Northern Ireland. Many thanks,
  • 1,511 Answers
Keep the end part and slip it over a new plastic tube obtained from a hardware store or tropical fish place. Take the original tube with you and get the exact replacement and length cut to order. Just replace it and your good to go.
Posted on May 09, 2014
  • 3 more comments
  • Debumere May 11, 2014
    Thank you but the gold part is firmly fixed and is on both ends. I can't get it off. Will give Krups a ring. Thanks
  • Dayton Computer
    Dayton Computer May 11, 2014
    In short, where the liquid pours out into the cup, you have no way to reach the ends to clean the port with a pipe cleaner or paperclip?
    It is where the water comes through from the tank , through two pipes and into the boiler. That is the tube. Limescale blocked the hole but the tube was cpelted
    completely distintegrated at one end. Limescale removed to allow liquid through but can't use it until there is a new tube. Nightmare!
  • Debumere Jul 10, 2014
    Thanks everybody for your advice! Good news! I got a company to make a replica tube for pennies (about $4). All set to use it except now I can't remember where this black box goes. Anyone got a picture of the inside of a Krups 874?
4 Suggested Answers
SOURCE: Recently my Krups 4050 espresso machine starting b...
It needs a new flow meter. I replaced the one in mine and now it works fine. I took the old one apart and the little magnet inside is a ferrite magnet which rusts over time when it comes in contact with water ( duh). If the new one does this I am going to just replace the little magnet with a rare-earth magnet which will cost about $1 or less and shouldn't rust out. I am wondering if the company changed the magnet in the new flow meter so this doesn't happen or if planned obsellesants, just last long enough to get it out of warranty, is the company's motto. The new flow meter was around $30 when the added the $9 for shipping.
Posted on Nov 19, 2011
  • 39 Answers
SOURCE: espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Posted on Dec 29, 2009
JetJedi221
  • 25 Answers
SOURCE: 2 problems: not enough hot water, and where the rubberized tube goes
It's my opinion that the tube goes in the boiler so that when the water boils, the steam will push the water up the tube and to the brew head. Without the tube, you will just get steam through the grounds.
Posted on Mar 10, 2008
Krups xn7106 leaking from base
You are going to need to remove the covers and run it up to observe where the water is leaking from. Any leak at all inside the housing from anywhere is going to come out the bottom. There are teflon tubes and O rings inside that shrink with time and heat. More likely to be leaking closer to the boiler where water is hottest. Just be careful running it up with covers off, remember electricity can kill you so look with your eyes not your fingers.
Dec 28, 2014 | Krups Coffee Makers & Espresso Machines
Spare warming plate for Krups CafePresso Crematic Time needed- part No. MS-0907973 for F8884310
It seems difficult to find spare parts. I would search for any used light damage or e-bay.
http://www.prixgagnant.com/product/krups-f8884310.html
Apr 03, 2008 | Kitchen Ranges
I dismantled my Krups espresso crematic 874 to replace a water tube. It's all there and in place but for a black box which looks like a cover. I don't know where it goes! Would anyone be able to take a...
Why not take a photo of the bit you have left over and show us what it looks like. Maybe then one of us can look up the parts sheet and tell you where it is likely to belong.
Jul 10, 2014 | Coffee Makers & Espresso Machines
What does "Locked Selection Level Timeout" mean
Would you like to explain exactly which machine you are having problems with,, generically the error message you have indicates that the machine is being starved of water, Level probe in boiler not sensing water in preset time. causes-- water turned off, water filter blocked, inlet valve failure, limescale on level probe. there are other causes but are machine specific.
Apr 30, 2014 | Franke Coffee Makers & Espresso Machines
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Sep 20, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
Recently my Krups 4050 espresso machine starting beeping repeatedly while making espressos. Same thing every time: espresso starts to pour out then machine beeps like something's wrong and doesn't finish...
May 19, 2010 | Krups Cappuccino/Espresso Maker -...
There isn't enough pressure to pump water through the coffee
Chalk in the system, let it run a couple of times with plain vinegar. just fill the machine with about half a liter (one water container) vinegar and collect the vinegar in a cup so you can reuse it. run the full 0.5 liter, wait an hour and repeat. Than run 2 full watercontainers plain water. should work again. Cheaper than antichalk fluid and works the same
Mar 17, 2009 | Krups Small Appliances Espresso Machine
Mar 10, 2008 | Krups Bravo Plus 872 Espresso Machine
Coffee Makers & Espresso Machines Logo
103 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
