What could be the problem with LCD tv?
When i turn it on it will click and a red LED blinks 5 times then click again, it will repeat this and wont turn on. removed the back panel found 2 blown capacitors, replaced these with the same rating tried it still wont turn on. if i hold the power button on the tv for about 20-30 seconds it will click and turn on.
  • 1,511 Answers
There is still a power leak and intermittent short on the circuit board. You did not get the entire board fixed. Check all diodes for polarity and openings. Test resistance values and look for any other unstable components.
Posted on May 09, 2014
Kdf-e55a20 red blinking light
Altho you do not say which light is flashing red , you have a light on the front that is for the lamp ONLY...
If you do not have the user manual , get it here & start on page 11.:=>...
http://www.retrevo.com/...myTrevo.jsp?page=man
Jul 06, 2015 | Sony KDF-E55A20 55 in. LCD Television
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Programming the jensen jr400 universal remote
1) Turn on the Proton TV;
2) Press the "TV" button on the JR400;
3) After releasing the button, the red LED indicator should blink twice;
4) Press and hold the SETUP button until the LED blinks twice;
5) Release;
6) Enter 9-9-1 on the numeric pad. Red LED blinks twice;
7) Press POWER;
8) If TV doesn't turn off, press TV again;
9) Repeat #4, #5, #6, and #7. If TV doesn't turn off, go back to #4, until the TV responds.
10) Go on to the next device, i.e. DVD, VCR, etc.
Feb 17, 2008 | Jensen JR400 Remote Control
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
