Question about Kenmore Side by Side Refrigerator
Where is the solenoid valve located? - Kenmore Side by Side Refrigerator
  • 151 Answers
Without more specifics, they're usually mounted down under or behind a panel on the outside of the back or a panel behind the icemaker inside the freezer(rare).
Posted on May 09, 2014
  • 1,511 Answers
The solenoid valve is at the connection where you screw on the hopes from the water supply to the machine.
Where is the front brake solenoid valve located on a KIA Sorento?
That is part of the ABS system and it is on the modulator. The modulator is the block with all the brake lines connecting to it near the firewall on the drivers side under the hood.
Jan 31, 2016 | Kia Sorento Cars & Trucks
Where is purge valve solenoid located?
Mar 16, 2014 - 2 posts - ‎1 author
I have a 2003 Vue 3.0L 2wd.After fueling I have trouble starting, it cranks but I have to pump it a couple of time then it starts, Sometimes after it ... 2008 Saturn Vue Purge valve canister solenoid location ...
Aug 24, 2013
access to vent valve solenoid - SaturnFans.com Forums
Jan 20, 2013
Service engine soon light: P0440 - SaturnFans.com Forums
Apr 15, 2010
Code P0446 (evap solenoid) and now I can't fill the gas ...
Nov 17, 2007
More results from www.saturnfans.com
EVAP Solenoid Location - YouTube
? 2:17
https://www.youtube.com/watch?v=jIKaPF2Yw3I
Mar 20, 2007 - Uploaded by richpin06a
Saturn EVAP Solenoid Location. ... How To Test and Replace EVAP Canister Vent Control Valve P0446 - Duration: 6:18. by CarsNToys ...
EVAP Purge Solenoid Removal - YouTube
Dec 11, 2015 | 2003 Saturn VUE
Need to know where to find the canister purge valve
For the location of canister purge valve,check the following help links mentioned below:--
Click the link :---
Location for EVAP Purge Valve Solenoid?
http://schematicsdiagram.blogspot.in/2012/06/2002-nissandatsun-pathfinder-location.html
How to disconnect the hose form the Evap Canister?
http://schematicsdiagram.blogspot.com/2011/12/how-to-disconnect-hose-form-evap.html
2004 Chrysler PT Cruiser: Location of EVAP Purge Solenoid Valve?
http://schematicsdiagram.blogspot.in/2012/06/2004chrysler-pt-cruiser-location-of.html
These will help.
Thanks.
Jan 08, 2013 | Cars & Trucks
Where are the shift solenoids on a 2000saturnsc1
The shift solenoids are located on the transmission valve body, the valve body is inside the transmission.
Jun 05, 2012 | 2000 Saturn SC
WHERE IS TORQUE CONVERTER CLUTCH SOLENOID LOCATED AT ON BUICK LESABLE CODE PO742
THE TCC SOLENOID LOCATED ON THE VALVE BODY. IF YOU HAVE RWD TCC SOLENOID BOTTOM PAN VALVE BODY IF YOU HAVE FWD VECHICLE TCC SOLENOID IN THE SIDE PAN VALVE BODY. RWD IS REAR WHEEL DRIVE AND FWD IS FRONT WHEEL DRIVE.
Aug 15, 2011 | Buick LeSabre Cars & Trucks
Code says evaporator purge solenoid
Which code specifically? Do not assume you need a new solenoid. Our recommendation will depend on the specific code and some troubleshooting results. I usually recommend checking over all the EVAP vacuum lines and the gas cap too whenever there is a purge valve code. Check the vacuum lines at the cannister in the left rear bumper. I will paste info on the purge solenoid below.
P0440 Evaporative emission (EVAP) system - malfunction
Possible causes: Hose connection(s), intake leak, EVAP canister purge valve
P0441 Evaporative emission (EVAP) system - incorrect flow detected
P0442 Evaporative emission (EVAP) system - small leak detected
Possible causes: Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
P0443 Evaporative emission (EVAP) canister purge valve - circuit malfunction
Possible causes: Wiring, EVAP canister purge valve, ECM
P0444 Evaporative emission (EVAP) canister purge valve -open circuit
Possible causes: Wiring open circuit, EVAP canister purge valve, ECM
P0445 Evaporative emission (EVAP) canister purge valve -short circuit
Possible causes: Wiring short circuit, EVAP canister purge valve, ECM
P0450 Evaporative emission (EVAP) pressure sensor - circuit malfunction
Possible causes: Wiring, EVAP pressure sensor, ECM
P0455 Evaporative emission (EVAP) system - large leak detected
P0456 Evaporative emission system - very small leak detected
Possible causes: Mechanical fault, hose connection(s), EVAP pressure "sensor
P0457 Evaporative emission system - leak detected (fuel cap loose/off)
Possible causes: Mechanical fault, hose connection(s), EVAP pressure sensor
P0458 Evaporative emission system, purge control valve -circuit low
Possible causes: Wiring short to earth, EVAP valve
P0459 Evaporative emission system, purge control valve -circuit high
Possible causes: Wiring short to positive, EVAP valve
Evaporative Emission Purge Solenoid
Description & Operation
The duty cycle EVAP canister purge solenoid (DCP) regulates the rate of vapor flow from the EVAP canister to the intake manifold. The Powertrain Control Module (PCM) operates the solenoid.
During the cold start warm-up period and the hot start time delay, the PCM does not energize the solenoid. When de-energized, no vapors are purged. The PCM de-energizes the solenoid during open loop operation.
The engine enters closed loop operation after it reaches a specified temperature and the time delay ends. During closed loop operation, the PCM cycles (energizes and de-energizes) the solenoid 5 or 10 times per second, depending upon operating conditions. The PCM varies the vapor flow rate by changing solenoid pulse width. Pulse width is the amount of time that the solenoid is energized. The PCM adjusts solenoid pulse width based on engine operating condition.
Removal & Installation
The duty cycle evaporative (EVAP) canister purge solenoid is located in the engine compartment near the brake master cylinder.
  1. Disconnect electrical connector at solenoid.
  2. Disconnect vacuum lines at solenoid.
  3. Lift solenoid slot from mounting bracket for Removal & Installation.
To Install:
  1. Position solenoid slot to mounting bracket.
  2. Connect vacuum lines to solenoid. Be sure vacuum lines are firmly connected and not leaking or damaged. If leaking, a Diagnostic Trouble Code (DTC) may be set with certain emission packages.
  3. Connect electrical connector to solenoid.
Purge solenoid location:
EVAP cannister location:
Nov 05, 2010 | 2000 Jeep Grand Cherokee
I am trying to locate the shift solenoid on a 2001 durango. Can anyone help?
WELL TRANSMISSION SHIFT SOLENOIDS INSIDE TRANSMISSION ON THE VALVE BODY.YOU WILL NEED A FACTORY TRANSMISSION REPAIR MANUAL TO LOCATE SHIFT SOLENOID.THERE IS MORE THAN 1 SOLENOID IN VALVE BODY.
Jul 08, 2010 | Cars & Trucks
CHECK ENGINE LIGHT CAME ON WITH CODE 1259. AUTOZONE SAID ITS PURGE VALVE SOLENOID. WHERE IS THAT LOCATED?
is a vtec solenoid valve. it located on your left behind the valve cover . vtec solenoid looks like a round cap. anyway do you have a oil leaks in your car?
Jul 27, 2009 | 1998 Honda Accord
Kenmore Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
