Question about Health & Beauty
What do hair pins look like ? - Health & Beauty
    Problem Solver:
  • 6 Answers
what do hair pins look like ? - 5_9_2014_8_45_37_pm.jpg Like this or 5_9_2014_8_46_04_pm.jpgAnything that keeps your hair neatly tucked. Like a thin version of a hair slide or clip.
Posted on May 09, 2014
How do you change fuel filter on 1995 ford explore
Make sure no fuel pressure on the system before taking anything loose. Usually if the vehicle sits overnight w/o the key being cycled, there isn't much if any pressure on the system, but, you still need to be aware. You could disable the fuel pump, then start the vehicle, that should drain the system. There other ways.
The filter should be toward rear of engine, driver side, under vehicle, attached to frame-rail. Hair-pin clips holds the fuel line, hopefully you can use your fingers to pull hair-pins back enough to remove fuel line and filter.
If your dealing with gasoline, there is a fire hazard, be safe, safety is your responsibility.
Jan 05, 2016 | Ford Cars & Trucks
I'm sad because no one payes attention to me. What should I do?
Dye your hair an unusual color and buy people dinner frequently.
Jul 19, 2014 | Cars & Trucks
Bose lifestyle fm aeriel socket broken where can i get spare parts as bose are charging 125 pound to repair!!
Hair extensions are a growing part of the online world and the world of glamour for ladies all across the world, thankfully now you can get the revolutionary Halo Hair Extensions which are the hair on a miracle wire at very low prices on the internet and because of worldwide shipping fees being so low it is easy to have them wherever you are in the world. There is no more high street shopping for hair and beauty products a few clicks online and they are delivered at your door. Very Glamour Ladies are a company I found that delivers worldwide and have an extensive range of salon essentials and products for all skin types. I wish I had found them sooner. The hardest thing is deciding what to buy each time. I am a dark brown colour with my hair but sometimes change it often, the colour match service was fantastic and with them being remy human hair extensions I can dye or change them whenever I want, even wash , blow dry and straighten them for maximum volume. Very Glamour Ladies
Mar 11, 2014 | Bose Audio Players & Recorders
How do I remove the ball pin from the lever of the andis master clipper?
Get a finish nail and stick it in back of the ball pin, hit it with a hammer until it pops out of the other side
Mar 03, 2013 | Andis Improved Master Hair Trimmer
I have the emachines model W3107 and am having problems turning it on and off. I have called emachines to order the part but they will not assist me because my computer is out of warranty. They do not even...
The On/Off switch is referred to as an ATX Power On switch.
Thought I would post that so it would make the switch simpler to search for.
This is one example of an ATX power on switch that I have found fits Many computers,
http://www.directron.com/atxswitch.html
The plastic button you push is the Power On Button assembly.
This plastic part can be heated with a hair dryer to soften the plastic, and easier removal of the defective Power On switch inside it.
{Hair dryer nozzle moved slowly back and forth on the Power On button assembly)
Usually there are two to three plastic tangs that protrude from the plastic housing, of the Power On button assembly.
These tangs are what hold the Power On switch in place.
After constant repeated heat from the inside of the computer, and due to age, the plastic becomes brittle. Breaks easily.
Heating the plastic should help prevent breakage.
Since the old Power On switch is going to hit the trash can anyway, you can also lower the entire assembly down in a bowl of fairly hot water. This to will help soften the plastic if a hair dryer is not available.
The new Power On switch has wires coming from it which connect to pins on the motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel connect to, is the Front Panel header.
The eMachines W3107 desktop computer uses an FIC K8MC51G motherboard.
(First International Computer)
http://www.fic.com.tw/product/motherboard/AMD/K8MC51G.aspx
This is the download page for the motherboard manual, for the FIC K8MC51G motherboard,
ftp://ftp.fic.com.tw/motherboard/manual/socket754/k8m-800m/
Click on the top file name >
25-11110-00(3-21-2006).pdf
After you click on the above file name, you may be staring at a white blank page for up to 30 seconds.
After the first page comes up it may take additional time to fully download the file.
{Took 40 seconds to see the first page, and the file was fully downloaded.
Medium speed DSL connection}
Page 20 has the Front Panel Connector (Header) pinout.
Orient the board visually so we are both looking at it in the same orientation.
Processor to the Top, Ram Memory slots to the Right.
The Front Panel Connector is to the bottom right corner, BUT not in the corner itself.
It is the second connector of pins, over from the Right outside edge of the motherboard.
Two rows of pins.
5 across the Top, 4 across the Bottom.
The Pins across the Top are numbered Odd.
Starting from the Right side of the motherboard going towards the Left,
Pins 1, 3, 5, 7, and 9
The Pins across the Bottom are numbered Even.
Pins 2, 4, 6, and 8. There is NO Pin 10. Just a blank spot.
A) Pins 1 and 3 are for the Harddrive Activity LED light. (HDD LED)
B) Pins 5 and 7 are for a Reset switch, IF used.
C) Pin 9 is Not Connected. {Not used}
D) Pins 2 and 4 are for the Power On LED light.
If a Dual Color LED is used it connects to the header to the Right of the Front Panel Connector.
The one in the very bottom Right corner of the motherboard. {3 Pins}
E) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Dec 03, 2010 | E-Machines eMachines Desktop PC
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Please help what to do with my canon MP145 - Hairpin in the paper
I do not understand what is your printer problem
please send me details clearly.I shall help you
Sep 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Needs new front wheel bearings 2003 taurus
Your hub, the tire mounts on the studs....also, you'll need to remove the brake caliper. There should be a nut in the center that has a metal hair-pin looking item through it. That needs to be removed to pull the rotor off. Then, The bearing pack needs to be knocked out of it from the side the tire studs are poking from to the other side where the axle is. When you replace then, load them full of bearing grease....set it in place and use a board or something solid ofver the top of them...or a socket equivalent in size...knock the new one in to the rotor. Take your time and make sure that it goes in evenly....tapping in a circular motion.
Installation is in revers order...try to NOT reuse that cottor pin (the hair-pin looking item).
Mar 14, 2009 | 2003 Ford Taurus
The cutter of the blade assembly barely moves. Oster A-5 Turbo
this pin or Post is moulded to the body of the clipper they only require replacement if you can move the post, alternatively there could be wear on the nylon drive lever or the gear try packing with clipper grease.
Nov 10, 2008 | Oster 76076-040 Hair Trimmer
Health & Beauty Logo
339 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
