Question about Pioneer GPS AVIC-X1 car radio
Pioneer x1bt resistor in cable?
I'm installing a pioneer x1bt and there is a cable that connects to the power supply to the reversing lights which may need a resistor in series with it. Anyone know what size (as in ohms) resistor I need to use please? Thanks in advance
informatica
  • 1114 Answers
SOURCE: Installing a Pioneer DEH-P77DH
You can download the manual from the link below: http://files-upload.com/files/461301/DEH-P77DH_install.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 26, 2007
SparkGap
  • 363 Answers
SOURCE: Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Posted on Sep 21, 2007
Cerfer39
  • 709 Answers
SOURCE: I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Posted on Nov 24, 2007
Eagleeyes
  • 199 Answers
SOURCE: pioneer keh 1700 instruction installation.
hi try http://www.pioneer.co.uk/uk/support/index.html
can only find the deh1700 not keh.
mark
Posted on Nov 25, 2008
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
How to play music with iPhone?
Buy a cable like the one below. Plug in one end to your headphone jack of your phone and the other end into any analog audio (Red and White RCA's) input of the receiver. Power on the receiver and turn the input to match the label of the input that you plugged into on the back of the receiver. Adjust the volume up and you're good to go. Have fun!
3ft Premium 3 5mm Stereo Male to 2RCA Male 22AWG Cable Gold Plated Black
Mar 23, 2016 | Pioneer Audio Players & Recorders
How many fuses are on my pioneer reciver vsx-d606s?
1 for the power supply and 1 for left and 1 for right channel, but every stage inside has also fuse-resistors resistors with a extra function to protect some components that are resistors the are mounted higher or different on the print .
Nov 04, 2015 | Pioneer Audio Players & Recorders
I have a pioneer avh-p2300dvd in my car and i hooked up the parking break input to +12 volts because i want to be able to watch dvd's while driving(for my son in passenger seat) now my screen is stuck...
The parking brake (light green) connection needs to be connected to a (-) ground (black) wire, not a +12V wire. While it won't damage the unit to put +12V power to that wire, it does need to see a (-) chassis ground to view video while in motion. If changing this wire to ground still doesn't offer the solution, your Pioneer may require wiring of a relay as is necessary on several newer Pioneer navigation units.
Some Pioneer radios will still not allow video to be viewed even if the parking brake wire is grounded. For these units, I recommend using a standard 12V automotive relay (Bosch type). I would recommend consulting a professional installer if you are unsure about wiring this relay. Otherwise, if you are comfortable/knowledgeable, the instructions for wiring the relay are as follows:
85 - chassis ground86 - Blue/white stripe (remote turn-on lead from Pioneer)87 - chassis ground30 - Light green (parking brake lead of Pioneer)
The wiring of the relay will cause the parking brake lead to see the ground wire at the same time that the Pioneer actually powers up. This delay can be necessary for viewing video. An optional timing device can be wired in to do the same function such as PAC electronics' PTR-7.
The message that you are receiving for "screen image may appear reversed" is typically only visible when a reverse camera is used. For this, the Pioneer has a separate purple/white stripe wire for +12V reverse input.
I hope that this information was helpful.- Elliot
Nov 09, 2011 | Car Audio & Video
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Pioneer DEH-4100 No power
if you dont have a 12volt power supply, you can test the headunit by connecting your yellow, red, and black wires directly to a car battery. connect the yellow and red wires to the positive terminal and the black wire to the negative terminal. Before doing this make sure the red wire has the small inline resistor supplied by pioneer and the yellow wire has a 10amp fuse.
May 19, 2009 | Pioneer DEH-P4100
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Avic X1BT gps has a mind of its own. voice directions keeps telling me to do U turns even on motorway. Previous routes cancelled OK, verbal only works intermittantly. High lighted direction on maps will...
Total factory reset then with wiring diagramme I downloaded for my car and help of Pioneer technicians connected in speed pulse. Cured Problem O.K.
Oct 11, 2008 | Pioneer GPS
Power has to reset with each restart
It sounds as though you may have the constant and switched power connections reversed. The yellow wire from the Pioneer head unit has to be connected to a constant power source, and the red wire has to be connected to a key-switched power source. Assuming that both are currently connected to different wires, try reversing them and see if that solves the problem. Otherwise you'll need to get a voltmeter and test the factory wires for voltage.
Jun 27, 2007 | Pioneer DEH-2700 CD Player
Pioneer GPS AVIC-X1 car radio Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
