Question about Philips 46PP9302 46" Rear Projection Television
Red is out of convergence
Green and blue line up, but the red doesn't.
Does anyone know who to call, or where to get parts to fix this?
    Problem Solver:
  • 8 Answers
Your TV has a convergence problem. You can get the parts, instructions, and repair support from www.TvRepairKits.com
Posted on Jul 31, 2009
  • Philips Master
  • 8,617 Answers
Heres the repair kit for your model which contains the parts plus instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Posted on Jun 22, 2009
3 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Posted on Nov 30, 2007
  • 905 Answers
SOURCE: Philips HD 60 No red convergence
they are the STK 392-120's ic's on the big heat sink , depending on the numbers in there they may have been replaced with the upgrade or are original , also this could be the cause of a resistor on the chips connection lines (6.8 ohm) , or even a bad solder connection , testing of these should be done before getting the ic's and heat sink compound or solder wick and solder for the job
Posted on Jan 08, 2009
My rear projection tv used to have green lines , now the color seems off and now its blue lines... How do i fix it. Color going out??
If colors are skewed or looks 3d it is a convergence problem.
Some sets when the convergence grid is called up will have green lines--green is fixed and red/blue adjusted to it.
To tell you how to fix I need to know brand and model number.
These are typical convergence problems--no two sets will look exactly the same.
May 16, 2012 | Televison & Video
I have a Toshiba CT-90121 and my convergence is off. I can adjust the blue and red in the menu but cannot aline them with the green crosshairs. Do I need a new green projector or something else?
You need to remove the convergence Board and repalace the convergence IC's and and replace electrolytic caps and check for resistors that have changed in value. You can getb the parts at www.mcmelectronics.com com or just purchase a new board at www.partstore.com .
Oct 07, 2011 | Toshiba 65HDX82 65" Rear Projection...
The screen looks like its in 3D, and when I push the convergence adj button red and blue lines, lined up green line is wavy.
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jun 28, 2011 | Hitachi 43GX10B 43" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Philips 46PP9302 46" Rear Projection Television Logo
208 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
