Question about SCHLAGE LOCK COMPANY Schlage BE365VPLY505 Plymouth Keypad Deadbolt
Can i purchase multiple keypad deadbolt with same key?
I purchased a keypad dead bolt and would like to purchase a keypad door handle but would like them to have the same key. I purchased at home depot.
    Problem Solver:
  • 10 Answers
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
Posted on May 29, 2014
    Problem Solver:
  • 15 Answers
Take the key to your present lock with you to home depot, and for a nominal fee, they should be able to pin the lock you are purchasing to your existing key, provided it is the same keyway. (ie. If one is a Schlage product and the other a Kwikset, no go) If your local home depot doesn't offer pinning services, an area locksmith would be your next option. You can bring the lock and key to their shop and drop it off for a rekey.
Posted on May 20, 2014
I bought a DEFIANT KEY PAD DEADBOLT.
Usually you just take it apart and turn everything around, the keypad would be turned over and the bolt would be removed and turned to the reverse of where it was.
If it is the type below, I am thinking you would remove the deadbolt part and turn it and then there must be something inside that reverses the throw of the bolt. No instructions with it?
Defiant Electronic keypad Deadbolt Satin Nickel The Home Depot Canada
Nov 11, 2015 | Defiant Stainless Steel Ball Entry Knob...
How do I remove the 10-year old "TITAN", locking dead bolt from my front door? I removed the interior turn-handle side, but can't get the outside (keyed side) off?
if the inside is off and you unscrewed the main long throught the door screws than it is more than likely just stuck on by paint, they clamp to the door from each side with those screws, if there a no visible screws then its just stuck
Oct 16, 2014 | Kwikset Titan Single Cylinder Deadbolt
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
Double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Oct 22, 2012 | Schlage Deadbolt. Double Cylinder Deadbolt...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have exactly 5 and 1/4 inches between the center of my deadbolt and door handle. Why do I need 5 and 1/2 inches? thanks
The standard sizes represent what is available in terms of the measurment from the door jamb plate and the center of the lever hardware. Your release handle will not operate correctly, both deadbolt and passage lock.
It sounds, however that you are referring to the distance between two items. The height of the deadbolt in reference to the door handle is not critical. It is dictated by looks, more than function.
Sep 17, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Aug 13, 2008 | Kwikset Professional Door Lock...
SCHLAGE LOCK COMPANY Schlage BE365VPLY505 Plymouth Keypad Deadbolt Logo
99 people viewed this question
Top SCHLAGE LOCK COMPANY Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a SCHLAGE LOCK COMPANY Lock and Locksmithing Expert? Answer questions, earn points and help others
