Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Why does the vacuum mode on my Hoover FloorMate SpinsScrub keep engaging?
The first 20 minutes I used this floor cleaner the unit worked great; however, the vacuum mode now keeps engaging while I am trying to use the scrub and/or dry modes. I will be using the unit in scrub mode and the vacuum will "click" on - I can hear the unit start the vacuum. It now won't work in scrub or dry mode for more than a few seconds before starting the vacuum. Help?
5 Suggested Answers
Kaoeria
  • 36 Answers
SOURCE: hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Posted on Feb 29, 2008
ukvacfan
  • 328 Answers
SOURCE: i need an operating manual for my hoover floormate
http://www.hoover.com/pdfs/manuals/H3000.pdf
You will need adobe on your PC/MAC to open this.
Posted on Mar 27, 2009
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
New hoover floormate deluxe does not seem to be cleaning tile floor
Take it to your local Hoover warranty station. You have a one year warranty. These new machines are giving some trouble.
Feb 19, 2015 | Hoover FloorMate Deluxe Hard Floor Cleaner
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
I need an instruction manuel for hoover floormate
The manual can be downloaded here; scroll down to "Product Details":
http://www.amazon.com/Hoover-H3000-Floor-Hard-Floor-Cleaner/dp/B00005R19P
Aug 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Unable to find recomended cleaner for floor mate, what can I use
Do NOT use ammonia...it will destroy the seals. #1 NEVER leave solution in the tank...and clean everything after every use. Lowe's and/or Home Depot have Bissels cleaner for the Hoover Floormate...also check Target and Walmart's sweeper dept. If ALL fails, you may use Zep Pine Cleaner (Home Depot) in a diluted 2oz. to 1qt. water...filling ONLY the little reservoir with this dilution!!!!! Good Luck.
Dec 28, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I can't find the cleaner?
The Lysol/Hoover Floormate is no longer available. Substitute Hoover floor to floor cleaner.
Apr 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Does not pick up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
