Question about Hotpoint Ovens
How to convert Hotpoint RGB745 oven and broiler from LP to Natural gas?
    Sergeant:
  • 435 Answers
Please get a service tech
Posted on Feb 11, 2015
  • 161 Answers
SOURCE: converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Posted on Jul 15, 2008
SOURCE: Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Posted on Oct 20, 2008
  • 128 Answers
SOURCE: Recently purchased Frig. gas stove.Want to convert
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Posted on Dec 22, 2009
Testimonial: "Advice was very helpful,after you telling me what to do it was only a matter of minutes til I had it adjusted!! Thanks kencid"
  • 494 Answers
SOURCE: convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Posted on Jul 20, 2010
rickead1
  • 1998 Answers
SOURCE: The pilot lights go out on their own after awhile
yes this would definetly cause the pilots to go out and you should refer to your manual on changing between natural and lp gas on some units not only do you have to turn the gas regualtor and flip the small set screw to the oppisite side but most also require you to change the orifices of each burner if not then the stove will not light Ive gone through a similar situation with a viking best thing to do would be to get ahold of marcone appliance parts and have your model number as well as make of the machine handy and find out the prive of a gas-lp conversion kit. Please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 01, 2010
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
Jan 06, 2012 | Lincoln Conveyor Oven - 1133-000-A
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Dec 22, 2009 | Frigidaire Ovens
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Maytag MGR5775QDW-TOP works ,broiler and oven don't
If you have lp makes sure the tanks are fill and unit is converted to lp.Same goes for natural gas
Nov 06, 2008 | Maytag CWG3100A Gas Single Oven
Jul 16, 2008 | Ovens
Converting aan LP oven to gas
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
51 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
