Question about Sony Handycam HDR-CX160 Camcorder
My cam only records 17 min of footage at a time???
My cam only records 17 min of footage at a time how do i fix this, it does not stop recording after 17 min it just cuts the rec and starts back but the few milliseconds between tracks are very tedious to edit at times, iv reset the cam b4 and it went up eo 32 min intervals but now its back to 17 min how do i fix this?
This sounds like it's one of two things: 1 - it's an over heating issue. This is to ensure than nothing gets damaged on the mother board or inside components - this most often found in Canon products. This is a very good feature. 2 - since you said it doesn't stop recording, it's merely make a cut point, it's more than likely cutting the footage to fit the FAT32 hard drive rules of not exceeding 4.4 GB of date for a single file. This is to help with post production work flow so you can edit easier and your system won't be as bogged down. All around this is a good feature. Helps in post production greatly.
Posted on May 10, 2014
  • cinemaeditor May 10, 2014
Junoon007
  • 1011 Answers
SOURCE: date and time superimposed over footage-HELP- IS THERE ANYWAY TO REMOVE IT. THERE ARE A FEW TIMES DURING THE FOOTAGE THAT THE DATE AND TIME DISAPPEAR AND AFTER A MINUTE OR SO IT RE-APPEARS.
Dear Sir/Madam,
Click this link for download the manual and check the setting is correct is to set or not?
www.vasst.com/HDV/hdvimages/HVR-A1Umanual.pdf
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 29, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Posted on Sep 02, 2008
  • 370 Answers
SOURCE: camcorder won't play recorded tape
Clean the head and try again
Posted on Dec 07, 2008
SOURCE: sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Posted on Jun 08, 2009
SOURCE: ERROR CODE AT START RECORD C:31:23
C:31:23 s reel error
try to change the tape,actually this problem is related to the tension ,new tape have more tension as compared to the old one(used one).
Posted on Jun 30, 2009
Can Aiptek A-HD 720P record footage from old games?
the A-Hd is the only Hi def camcorder of Aiptek to record into the camera the Av input iti s called. the A-hd has a lower gain of the mic meaning all video recording of the actual live footage will be low on older models possably normal on the newer today
the Go-hd does not record any footage into thecamera no AV input it will have a higher gain meaning the sound going into the camera will be too loud there is no medium level
Apr 21, 2017 | Aiptek A-HD 720P Flash Media Camcorder
Hi. Video recording / playback issues!
You need a computer with a better video card and more RAM.
Mar 23, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Camera won't record/ play footage.
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
May 31, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Recording using A/V in jack - 18 seconds max allowed
Well there could be a couple things- A. there is a problem with the camcorder's software, which will need to be fixed by a LONG phone call with Aiptek Support B. You could be using the wrong component cables for your TV C. You could have the quality set TOO high for your TV's (The PS2 is NOT HD) I recommend DVD quality for this
Hope this helped, sincerely- animation508 (youtube username)
Jul 26, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Non Displaying of recorded footage
If you put in a empty tape and record something to it does the same problem happen?
Would seem a like a problem in the reader.
Jul 17, 2008 | Cameras
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
Sony dcr-hc35e
first try a cleaning tape and this will not solve the problem have a service dealer check the unit.ru the cleaning tape once and try to playback a good old recording, if it does not work try to run the tape twice before testing . do not run the tape too many times as you may damage the video heads.one cleaning session should not be longer than 10-15 seconds. most of the new cams are stopping the cleaning tape playback after 10-15 secs.
Jul 04, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Sony Handycam HDR-CX160 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
