My LG washing machine has just stopped spinning and draining when it's supposed to do that it's just flashing something like 30 with the 3 facing the opposite direction
  • 41 Answers
Check your filter and make sure drain is ok sounds like the pump is either not working or blocked.
Posted on May 11, 2014
Rotu
  • 175 Answers
SOURCE: Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Posted on Oct 17, 2006
SOURCE: f 21 flashes
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
Posted on Jan 31, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
My Crosley CAW8350EW1 wash machine just stopped after the last spin cycle drained and the spin light keeps flashing. I'm wondering if that would be the timer or something else?
make sure that it didn't stop because of an unbalanced situation
as it is draining it should be turning slowly and as soon as it empties the spin speed picks and and the unbalance stops the machine
Mar 14, 2017 | Crosley Washing Machines
LG tromm spins on washer,but doesn't on rinse and won't drain
ur confusing me its not suppose to spin first , first it rinses, then drains then spins
Jul 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG WM0642HW it stopped draining, and sounds like pump is spinning but no water. I opened the filter plug and no obstuction and tried draining with small hose no water. but there is still water in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | LG WM0642H Front Load
My lg washing machine is flashing OE i have looked at my manual and ir says to clean drain filter and clean drain hose! done the filter which hasnt helped and how on earth am i supposed to clean the pipe...
Could be a manufacturers glitch ,might want to cal a servoice center to see . Basically the washer is having problems draining ,check the drain hose going to the tub sink and make sure it isnt up in the air or something. Another posibbility is that the hose or drain has something in it backing it up to a sensor,could run some bleach through it to see if it clears
Feb 17, 2011 | LG Washing Machines
MY WASHER STOPS WORKING WHEN IT IS SUPPOSE TO DRAIN TIMER EVEN STOPS WHAT COULD BE WRONG?
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 09, 2011 | LG WFT1071TP Top Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Bosch WFLI 2440 Front Load washing machine stopped working
filter is probably the problem. the round cap unscrews and then just pull filter out
Sep 07, 2008 | Bosch WFLI 2440 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
