Question about New Ray 112 Scale Bombardier Sea-Doo XP Diecast Jet Ski Model
2000 seadoo gsx wont start blown alsoblew fueses in start relay compartment and mpen fues changed but still no start with new mpan my display stay on now with my key out ?
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
Why after I flipped my seadoo and got water in the motor, it wont stay on without pressing the start button, why? how can I fix this? The seadoo is a 1999 xp
I would say that you shorted out the item on the other end of your start switch due to it working backwards. Check the continuity of the wires from switch & check the switch.
Jul 21, 2014 | 1999 Chevrolet Silverado 1500
2003 seadoo challenger. how do you adjust the trim to keep the boat from hopping or bouncing?
To stop the bouncing,you need to trim in or down.Adjust the weight on the ski forward.The best site for seadoo is seadooforum.It will solve any and every problem you ever thought of for Seadoo,s.Hope this helps
Jun 15, 2010 | Boating
1998 Bombardier Sea Doo leaks, after water gets into the engine compartment it runs badly. Our local seadoo mechanic can not find the leak. Any suggestions? Thanks
pull out the spark plugs and put the cooling line on the motor and turn on the water see if you have a crack in the cylinder walls or a blown head gasket.
Apr 30, 2010 | Boating
New Ray 112 Scale Bombardier Sea-Doo XP Diecast Jet Ski Model Logo
Top New Ray Toys Experts
Josh Van Nostrand
Owen Barnes
Bruce Burgess
Level 1 Expert
Are you a New Ray Toy Expert? Answer questions, earn points and help others
