Question about Brother International Office Equipment & Supplies
Mfc j27ow The printer reads the data but when it goes through and prints there is nothing on the paper. No ink is being dispensed
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Brother Inte... Expert
  • 234 Answers
You have a Faulty PrintHead or You need to make CLEANING the machine at least 4 times from the machine's Panel
Posted on Aug 01, 2014
  • 68 Answers
SOURCE: Printer "prints" but when it's done, no ink shows on the page.
When you filled your cartridges were they empty? If so there is a good possibility that the nozzles are gummed and dried up. If you are going to fill them yourself watch the indicator that comes up on the screen it will tell you when you are getting low. If you get a low indication fill it asap. This will keep your nozzles wet and free flowing. Waiting until its empty can cause them to gum up and altimately dry out. My solution is to go to the store buy brand new cartridges. Go through the the full set up that your manufacture recomends. This means using the install new ink cartridge utility that came with your printer. Print a test page and print a nozzle aligment page. Just remember never let your ink completely run out before filling. If you follow this you will never run into this problem again.
Posted on Sep 21, 2007
SOURCE: Canon Mp480 wont print!
My printer is less than 2 months old. I have the same problem as Amanda. Paper goes through the printer, but doesn't print anything. I am now doing a full cleaning, a nozzle check, and print alignment check.
Posted on Apr 11, 2009
aicaxz
  • 511 Answers
SOURCE: Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
Posted on Jun 01, 2009
bolinlamar
  • 157 Answers
SOURCE: brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Posted on Sep 04, 2009
celibytes
  • 70 Answers
SOURCE: My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Posted on Sep 10, 2009
Clean print heads brother MFC J425W
This is what I figured out to get the printing back to normal.
Open up the printer so you are looking at the place where the print heads go back and forth, you will also see the paper feeder. In the back left corner is where the ink is dispensed. There was build up on mine. As usual grab a 10 or so q-tips and some rubbing alcohol and clean the build up of goopy ink.
You won't ever get it completely clean because more ink will keep dispensing. Close it up and run a test print again.
Jan 25, 2013 | Brother MFC-J425W Inkjet Multifunction...
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
My Brother MFC-495cw will not print. It pulls paper through but nothing prints.
This is due to the ink...Check you ink cartridges if they are still full of if the ink has dried out thats wht printing is not working
Jun 11, 2010 | Brother MFC 490cw Color Inkjet...
The paper jams when I try to print. How do I load
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.4all2sell.com/pdf/Brother-MFC-7340-MFC-7345N-Manual.pdf
Feb 24, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Sep 16, 2009 | Brother Multi-Function Center MFC-240C...
Sep 10, 2009 | Brother MFC-290C Printer
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
Cyan ink was full - now it's empty a day later?
Aug 04, 2008 | Brother MultiFunction Center MFC-440CN...
35 people viewed this question
Top Brother International Office Equipment & Supplies Experts
k24674
Gil Shultz
Ron Baird
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
