Question about Sewing Machines
Why is my jones 568 breaking the thread - Sewing Machines
  • 3 Answers
Check your bobbin tension and installation. The bobbin is the most likely problem.
Posted on May 09, 2014
568 jones gives elect shock put bear feet feet on pedals no elect
Rehman, are you wearing wool socks and getting static shocks, ensure your cable(wire) is in good undamaged condition or replace.
press the helpful button and follow me for more tips
Feb 10, 2016 | Sewing Machines
Thread my sewing macine
There is a site that has a manual for this machine for sale. Site is here : http://sewingonline.co.uk/jones-brother-manuals-2.html
Threading most machines is not hard, if you have a pic of the front of the machine, fairly close up, I could probably tell you how to thread it. But having the manual is always a good thing.
Oct 09, 2014 | Sewing Machines
Threading Jones Serpentine sewing machine
I will be puttng up some pictures on my facebook which can be accessed via www.justsew.info of mine threadded later today, I dont think the previous posters understand quite the age of these machines
May 21, 2012 | Sewing Machines
I have a jones 942 sewing mahine
you'll probably have to email them about the manual
sewvacdoctor.com
a1sewingmachines.com
try changing the needle
clean under the needle plate & in the bobbin area for lint or loose thread
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
Lower thread breaks
bent bobbin--replace
thread catching on the bobbin spring or latch on bobbin case check to see that the bobbin is inserted completely & correctly & that you are using the right kind of bobbin .
Thread is bunching up and pulling fabric into feed dogs. also breaking top thread. i have cleaned and oiled,adjusted stitch length,changed needle, re-threaded, and adjusted tension. i should note i am a...
If the thread bunches up on the bottom sometimes it is the bobbin tension. You can remove the bobbin housing and may notice a screw. This screw "tensions" the tab where the thread goes through, creating tension on the thread. Another thing to check if the machine is on a "loose/stretch" stitch setting, this will allow the elastic to freely expand and contract. You may need to also adjust the "speed" of the feed teeth, to compensate for the slack. Often there is "stray thread" in or around the bobbin, which can cause problems, One of these may be the solution, Im being general in my information.
Mar 21, 2010 | Singer 7442 Mechanical Sewing Machine
Need to know how to set the tension to sew hems on
Re-thread the machine and make sure that the needle is in properly. The tension would not cause the thread to break.
If it is not working, what is the machine doing? Try re-threading the machine again, check the needle to make sure that it is in correctly. There are no set numbers for tension- it is a feel, push, pull. If you could e-mail me back with a better description of what the machine is doing or not doing,
Aug 31, 2009 | Brother Sewing Machines
JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Feb 21, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
