Question about Sony Acid Music Studio 7 Full Version for PC (SAMS7000)
Monitoring recording using acid music studio 7
I cannot monitor while recording, I know that I am recording because I can see sound waves and I can hear the recording once I take out my USB CAD mic?
The program doesnt come with that option only pro does
Posted on Jul 07, 2009
Im Using Acid Music Studio 8.0 With & Xenyx502 Mixer. Every Time I Record It Sounds Fine But When I Play It Back When Im Finished Its Off Beat How Do I Fix This??
check the "buffer" setting - set to the lowest number possible. You can't eliminate the "latency" but you can reduce it a lot. Also 0 try to monitor what you are recording with "live" sound (input instead of output) - also, you may need to download a different driver for your audio card, try ASIO4ALL
Oct 13, 2013 | Lexicon Alpha Personal Recording Studio
I have a Fostex DMT-8vl 8 track digital recorder. Can I dump the tracks to Acid Music Studio 7 or Acid Pro 7 to save what I recorded in the Fostex 8 track, and will it go into seperate tracks? Thanks...
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Jul 21, 2010 | Sony ACID Music Studio 7
My record button ib Acid studio 6.0
that happen while u was recording some thing ???
Aug 21, 2009 | Sony ACID Music Studio 6 Full Version for...
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
Not Able to monitor recording
i am not hearing my music that i wont to record
Mar 20, 2009 | Sony Acid Music Studio 7 Full Version for...
Acid 7.0 music recorder
It sounds like the software is having trouble locating a recording device. If you go in to the settings for the application, you should be able to select/see the audio input devices. Does the device you are trying to record to show up and is it selected as the active recording device?
Feb 19, 2009 | Sony Acid Music Studio 7 Full Version for...
Can't hear MIC through HEADPHONES in real time
Hi
i hope that you have the audio drivers installed and working and of course tested with your headphone..best way to do this is to play any song in media player and monitor it on your headphone...
the default settings for most DAW( Digital Audio Workstations) including ACID will be to mute the audio output when recording. This primarily is done to avoid feedbacks during recording. Anyways coming to the point. Since people would like to hear whats been recorded there is a scheme called as direct monitoring. I believe in ACID it is called as "Input Monitoring" and it basically is a small speaker shaped icon that appears next to the Record Arm Button once it is armed. Click on Input Monitoring and make sure its turned ON. Now you can listen while u record.
Hope this helps...contact me if u need further help
Jan 19, 2009 | Compaq Presario Notebook
No sound coming through speakers from microphone
ok i have windows vista so u have to right click on sound icon speaker then click playback n select conexant high definition smartaudio 221 n right click it as default n u gotta re load up acid then right click n insert audio
Dec 14, 2008 | Sony Acid Music Studio 7 Full Version for...
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Sony Acid Music Studio 7 Full Version for PC (SAMS7000) Logo
856 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
