Question about Klipsch FREETALK TALK 5191 Wireless Headset
What do I do to couple or pair a TALK 5191 wireless headset
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Some Questions from germany: In which way is the headset connecting? is it possible zu use just the headset with another transmitter? i mean without the usb dongle - in wich way is it wireless?...
The wireless headset will not work with the USB charging cord plugged in The battery is 3.7 volts at 350 mAh
The physical size of the battery matters too, it has to fit inside the headset. The dimensions are as follows Approx 5.5mm thick by 25mm wide by 35 mm long or .25 X .9375 X 1.25 inches I am sure that some one make Re-chargeable Li-On Battery this size , I just am having problems locating one. Any help would be appreciated Thanks
ole Blake
Aug 19, 2011 | Klipsch FREETALK TALK 5191 Wireless...
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I cant talk to anyone and how do you talk to them
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Oct 21, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I want to pair the motorola H500 to my blackberry pearl. i cannot get the bluetooth in pairing mode?
-Be sure the headset is fully charged.(plug it in till the light turns off.)
-Hold the talk button down for 4 seconds or until the blue light goes solid (not blinking.)
Now the device should be ready to pair with your Blackberry. It usually only stays in pairing mode for a short while (approximately 90seconds)
Jun 30, 2009 | Motorola Mobility H500 Wireless Headset
I charges my wirless mic and when i turn it on it
pair the headset to the xbox by pushing the small button on the xbox and the small button on your headset once it pairs make sure the number on the headset on the headset is the same as the number on the controller otherwise you wont be able to hear or talk to people online
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR SOLUTION TANKS.
Jun 11, 2009 | Microsoft Wireless Headset for Xbox 360
TRYING TO PAIR THE H700 TO MY TMOBILE WING
Just have to re-pair it.With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 28, 2008 | Motorola Mobility H700 Wireless Headset
How to synchronize to my phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect. This headset can sync with laptop.
Nov 24, 2007 | Motorola Mobility H700 Wireless Headset
Klipsch FREETALK TALK 5191 Wireless Headset Logo
Top Klipsch Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Klipsch Radio Communication Expert? Answer questions, earn points and help others
