Question about Speck Pumps Pool & Spa
My pool pump won't turn on. I am just filling my pool for the first time this year. What could the problem possibly be since I am reactivating my pool for the season? bryanflake1984|
    Sergeant:
  • 269 Answers
Look for a fu
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Posted on May 09, 2014
Dreammaker 400 spa won't heat up
make sure recirculation pump on then check heater element then pressure switch then loud motor you hear
May 21, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
I'm trying to drain a pool that's Ben sitting for years full of nasty water. Pump works and operates but the fill pot on the pump itself will not stay full
Sounds like you're trying to pull water from skimmer and main drain. Soon as the level goes down, it sucks air from skimmer. Turn off skimmer line. If that's not possible, then cut off input side of pump(front pipe) and run new line to pool. Just lay it on top of ground and keep it below top by a couple of feet. This will stop all the **** on the bottom from plugging up the pump.
Mar 08, 2011 | Pentair Pool & Spa
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
I am looking for the most energy efficient way to run a 10,000 gallon indoor pool 365 days a year. Would i need a timer to optimize my electricity savings with the use of a Pentair IntelliFlo 4x160 pump or...
You run a pool pump based on pumping volume compared to pool volume and long enough to turn the water over frequently enough to keep it balanced and clear.
You should have no need to run it 24 hours a day to accomplish that since the pool is indoors and safe from the effects of weather and sunlight.
What you will want to do is determine the minimum amount of time then the pump needs to operate to keep the water balanced and clear based on fill water makeup, your chemical choices and bather loads and then set the timer to run the system for that amount of time and the pump for the speed required.
If you really want to be sure you are as efficient as possible you will need to look at the pump curve for your exact model and look for the point on the curve the pump is most efficient at, speed/volume wise and run it at that setting for the time you find thru experience mentioned above. That way the pump moves the most water it can at it's most efficient point for as little time as is required to keep the pool clean.
I hope I worded that in a way that makes sense.
Dec 07, 2009 | Pentair Intelliflo Pump 4x160
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
74 people viewed this question
Top Speck Pumps Pool & Spa Experts
k24674
Gil Shultz
Jay Finke
Jay Finke
Are you a Speck Pumps Pool and Spa Expert? Answer questions, earn points and help others
