Why does the light fladh green and then stay green even though there is no battery in it!?
I can't charge my phone now. When I plug the charger in, the light flashes green like it would when it is charging, before eventually remaining constant green. The Red light is on too. Despite sometimes getting it to flash when the battery is in, it doesn't charge.
    Novelist:
  • 206 Answers
If you can remove the battery, remove it.. Wait about 30 seconds+ Then place the battery back in and try charging it again. This is a solution that fixes quite a high percentage of battery related issues.
EVEN works with laptops. Hope this helps. So many other issues could be wrong with your phone or source of power.. Good luck.
Posted on May 13, 2014
ginko
  • 19396 Answers
SOURCE: My Xantrex Powerpack 200 Plus
Hi.
The power pack battery is faulty, the red light and the clicking noise when not connected are symptoms of a state called protection. When the unit is connected to AC protection kicks in because the battery is detected as faulty. The clicking noise is a safety switch that keeps turning the charger off.
To get a quote on repair contact Xantrex. Here the page.
Posted on Sep 12, 2010
  • 2666 Answers
SOURCE: acer aspire 3050 new battey will not charge
Sometimes batteries need a full 24 hr initial charge before they will work. You would be advised not to use the M/C during this period. Also it will take several charges before the battery reaches it's optimal performance.
This could be the problem so it's worth a try.
Posted on Aug 21, 2009
  • 231 Answers
SOURCE: regarding battery problem/battery not charging
Hi Jasbir, Laptop batteries only have a set life span and if your battery does not hold charge the only solution is topurchase another battery. You will find the cheapest way to do this is to search the computer section of ebay [laptop assessories ]
and find the battery for your laptop model.
Regards mistyman
Posted on Nov 17, 2007
  • 3940 Answers
SOURCE: I have a Dell Inspiron 6000 the battery light is
here ya go
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
Posted on Nov 15, 2010
SOURCE: I have a HP/Compaq 6510b
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Posted on Feb 17, 2011
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
18v Litheon drill charger won't charge battery. Green light stays solid even though battery is dead.
It could be the battery or the charger. Best thing to do is find a Bosch service center and have them test them. The litheon stuff is fairly new, there is a good chance it will be on warranty.
Oct 17, 2009 | Bosch Drills
Phone dies and will not charge
Your Battery Is maybe Too Old, If the Phone Is Very old Then The Battery Is Just dead Because Of too much Use.
Hope it helps.
Sep 22, 2009 | Samsung Lands Phones
Won't turn on
Your battery is dead. get a new battery
Aug 19, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Mintek 8" TFT portable dvd player MDP1810
DO NOT continue to try to charge that battery. The company recalled those batteries because they explode or start on fire. Do a google search of "mintek" and you can read about the recall.
Jan 10, 2008 | Mintek MDP-1770 Portable DVD Player
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
