Question about Acer Aspire One PC Notebook
Bios 3309 black screen
Acer aspire one won't load windows only a year old
Just go to website: http://support.acer-euro.com/drivers/notebook/as_one_150.html, and download the bios update 3309, open the folder and copy two files to a formatted fat usb stick. Rename the file FLASHIT to FLASHIT.EXE and the second file 3309.fd(bios file) to ZG5IA32.FD rename them precisely like that, please check your spelling is correct. Insert the usb stick into the usb left hand side make sure the charger is plugged in . Hold down keys fn+esc and power up the laptop, when the power led begins to blink release the two buttons and press the power button just once, observe the usb stick flashing indicating it's flashing the bios, please note this can take a few attempts, I once struggled for a few hours until I finally tamed the beast :) be patient okay, I would like to point out if you wish to update within winxp use the same bios update 3309 , extract the zipped files to a formatted usb stick and rename the two files again but DO NOT REMOVE or interfere with the other files in the folder , with the laptop up and running open the folder and click on the Insysdeflash file only within the winflash file, this will flash your bios within windows and update it to the latest version, I read that flashing it when using the fn+esc keys merely restores the bios , I have tested this and mine updated to 3309 only when I flashed my bios within windows using the complete d/loaded bios update as mentioned . It will be worth reading the read me file to see what has changed in this bios version, I can tell you that for those out there that have password issues i.e. hdd set, the need to enter password with upper case is not a requirement more and there are a lot more fixes too, enjoy and I hope this bit of info was useful:)
Jul 12, 2011 | Acer Computers & Internet
Acer won't boot
Just go to the acer website and http://support.acer-euro.com/drivers/notebook/as_one_150.html and d/load the bios update 3309, open the folder and copy two files to a formatted fat usb stick. Rename the file FLASHIT to FLASHIT.EXE and the second file 3309.fd(bios file) to ZG5IA32.FD rename them precisely like that, please check your spelling is correct. Insert the usb stick into the usb left hand side make sure the charger is plugged in . Hold down keys fn+esc and power up the laptop, when the power led begins to blink release the two buttons and press the power button just once, observe the usb stick flashing indicating it's flashing the bios, please note this can take a few attempts, I once struggled for a few hours until I finally tamed the beast :) be patient okay, I would like to point out if you wish to update within winxp use the same bios update 3309 , extract the zipped files to a formatted usb stick and rename the two files again but DO NOT REMOVE or interfere with the other files in the folder , with the laptop up and running open the folder and click on the Insysdeflash file only within the winflash file, this will flash your bios within windows and update it to the latest version, I read that flashing it when using the fn+esc keys merely restores the bios , I have tested this and mine updated to 3309 only when I flashed my bios within windows using the complete d/loaded bios update as mentioned . It will be worth reading the read me file to see what has changed in this bios version, I can tell you that for those out there that have password issues i.e. hdd set, the need to enter password with upper case is not a requirement more and there are a lot more fixes too, enjoy and I hope this bit of info was useful:)
Jun 16, 2011 | Acer Computers & Internet
The Aspire One PC Model ZG5 will not boot. No noise, nothing. The battery light stays on when the adapter is plugged in.
That's a biggie.
Well, it could be that your ON button isn't doing the necessary contacts and, of course, if it doesn't do the contacts nothing will happen.
It could also be a lot of things, the motherboard, the memory (though usually boots-very few cases where it doesn't), the powersupply (even with power indicators it might be broken).
BUT if what you mean is that you are getting a blank screen with no sounds.
Here is something I found on the issue:
Good luck
Feb 21, 2011 | Acer Aspire One PC Notebook
Acer one laptop want boot. it keeps looping back to the same screen.
Hi Gibbs,
Just go to the acer website and http://support.acer-euro.com/drivers/notebook/as_one_150.html and d/load the bios update 3309, open the folder and copy two files to a formatted fat usb stick. Rename the file FLASHIT to FLASHIT.EXE and the second file 3309.fd(bios file) to ZG5IA32.FD rename them precisely like that, please check your spelling is correct. Insert the usb stick into the usb left hand side make sure the charger is plugged in . Hold down keys fn+esc and power up the laptop, when the power led begins to blink release the two buttons and press the power button just once, observe the usb stick flashing indicating it's flashing the bios, please note this can take a few attempts, I once struggled for a few hours until I finally tamed the beast :) be patient okay, I would like to point out if you wish to update within winxp use the same bios update 3309 , extract the zipped files to a formatted usb stick and rename the two files again but DO NOT REMOVE or interfere with the other files in the folder , with the laptop up and running open the folder and click on the Insysdeflash file only within the winflash file, this will flash your bios within windows and update it to the latest version, I read that flashing it when using the fn+esc keys merely restores the bios , I have tested this and mine updated to 3309 only when I flashed my bios within windows using the complete d/loaded bios update as mentioned . It will be worth reading the read me file to see what has changed in this bios version, I can tell you that for those out there that have password issues i.e. hdd set, the need to enter password with upper case is not a requirement more and there are a lot more fixes too, enjoy and I hope this bit of info was useful :) --- regards
Nov 01, 2010 | Acer Aspire One PC Notebook
SCREEN IS BLACK
i have this problem 2 days ago.. and this works on me... maybe on your's too
you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios
how to flash the bios:
STEP 1.download the AA1 BIOS from this link:
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
2. extract the file
3. rename the file 3309.fd to zg5ia32.fd
4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2
A. make sure the power cable is in
B. the laptop is turned OFF
C. Plug the usb stick in!
STEP 3:
Press and HOLD down the FN and ESC key together
then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds
release the buttons and the power light will start to blink
let the laptop run and DO NOT PRESS anything this can take upto 8 mins
when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Jun 15, 2009 | Acer Aspire One PC Notebook
Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Same problem
Black screen
press F8 key when u start your laptop thene nter in enable vgs mode.
Then go to dispaly propert then change resolution to 1024*768
Jun 13, 2009 | Acer Aspire One PC Notebook
Black screen on acer aspire one .tryed download the bios from acer on usb.it works but computer clicks on and off still black sreen.no lights at all just power lights.
TRY THIS AGAIN............ i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 10, 2009 | Acer Aspire 5100 Notebook
Brand new acer aspire 7730 wont run intial start up
You can start the Recovery from outside Windows by holding down ALT and F10 on the Acer BIOS splashscreen on power up.
Jan 18, 2009 | Computers & Internet
Acer Aspire One  PC Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
