Question about Epson Stylus C120 InkJet Printer
How to type an address onto a std bussiness envelope
A standard business envelope(dimensions: width 9 @ one-half inches
width cannot be inserted, horizontally, into the stylus c120 injet"s
carriage for the purpose of typing an address upon it. since the carriage
is too narrow to accommodate the envelope. Of course, a person could
insert the envelope into the printer"s carriage, VERTICALLY, BUT, THEN,
how does a person go about the process of "CENTERING" the address,
when attempting to TYPE the address upon the envelope?
    President:
  • 3,085 Answers
Insert the envelope vertically. In your word processing program you should have an option for printing envelopes; usually in the TOOLS menu. Your program will figure out how to center the text.
Posted on Jun 22, 2009
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
May 30, 2012 | Canon PIXMA MX310 All-In-One Printer
I have a Jenn air c221 cooktop in need of replacement what are the dimensions of this unit.
Here are the dimensions for the Jenn air c221 cooktop. Hoping this will help.
width 29 15/16th of an inch.
depth 21 9/16th of an inch.
cutout width is 28 7/8th of an inch.
cutout depth is 20 15/16th of an inch.
Feb 04, 2011 | Cooktops
How to print a envelop
find ur envelop size.
setup ur page in word
type the address
print
Aug 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
What are the measurements for the most common business envelopes?
Commercial business envelopes sizes are often referenced by a number such as #9 or #10.#9 is (Width x Length) 3 7/8" x 8 7/8" and #10 is 4 1/8" x 9 1/2"
Aug 12, 2010 | Canon Office Equipment & Supplies
When trying to print #9 envelopes on our Phaser 8560, I'm not given #9 as an option. Is there a way to force it to print to #9's? It seems crazy to me that such a common envelope isn't listed.
In the envelope selection you should also have a custom size so you can input the #9 dimensions and have it print. You just select custom size and input the length and width of your envelope.
Dec 07, 2009 | Xerox Phaser 8560DN Laser Printer
I have a Lexmark C510, how do I print a business envelope?
You can load up to 10 envelopes in the standard tray. Try a sample of any envelopes you are
considering using with the printer before buying large quantities. See Loading envelopes in the
standard tray
for instructions on loading envelopes.
When printing on envelopes:
To achieve the best possible print quality, use only high-quality envelopes that are designed
for use in laser printers.
Set the Paper Source in the Paper Menu based on the source you are using, set the Paper
Type to Envelope, and select the correct envelope size from the operator panel, the printer
driver, or from MarkVision Professional.
For best performance, use envelopes made from 90 g/m2 (24 lb bond) paper. You can use up
to 105 g/m2 (28 lb bond) weight for the 250-sheet standard tray or 105 g/m2 (28 lb bond)
weight for envelopes as long as the cotton content is 25% or less. Envelopes with 100%
cotton content must not exceed 90 g/m2 (24 lb bond) weight.
Use only new, undamaged envelopes.
For best performance and to minimize jams, do not use envelopes that:
Have excessive curl or twist.
Are stuck together or damaged in any way.
Contain windows, holes, perforations, cutouts or embossing.
Use metal clasps, string ties, or metal folding bars.
Have an interlocking design
Have postage stamps attached
Have any exposed adhesive when the flap is in the sealed or closed position
Have nicked edges or bent corners
Have rough, cockle, or laid finishes
Use envelopes that can withstand temperatures of 170°C (338°F) without sealing, excessive
curling, wrinkling, or releasing hazardous emissions. If you have any doubts about the
envelopes you are considering using, check with the envelope supplier.
Adjust the width guide to fit the width of the envelopes.
Load only one size of envelope at a time in the tray. Envelopes may only be loaded in the
standard tray. Load them with the flap down and the flap to the left of the tray.
A combination of high humidity (over 60%) and the high printing temperatures may seal the
envelopes.
Loading envelopes in the standard tray
The recommended stack height is 10 envelopes; however, in normal environments as many as 15
envelopes may be loaded. In high temperature or humidity environments, only seven envelopes
should be loaded.
1 Pull the standard tray completely out.
2 Squeeze the length guide tabs together as shown in step 2 on page 42. Slide the guide to
the correct position for the size of envelope you are loading.
3 Squeeze the width guide tabs as shown in step 3 on page 42. Slide the width guide to the
correct position for the size of envelope you are loading. Notice the size indicators on the
bottom left of the tray.
4 Push the envelope stack aid tabs toward each other. They snap into place.
5 Flex a stack of envelopes back and forth and then straighten the edges on a level surface.
Press down the corners to flatten them.
Fan the envelopes. This prevents the edges of the envelopes from sticking together and helps
them feed properly.
6 Load envelopes flap side down with the stamp area and flap on the right. The end of the envelope with the stamp area enters the printer first.
7 Insert the standard tray.
Feb 26, 2009 | Lexmark C510 Laser Printer
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do I override the paper size on a Canon imagerunner 2200?
I have an image runner 2800 and I had the same problem. It drove me crazy I searched the entire menu. I finally figured it out. Pull out the paper tray which you want to change. There is a small dial on the right side with paper sizes on it. Select the right on and put the tray back. Your paper size should now have changed on the menu. You are welcome :-)
Apr 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Loading envelopes
To load envelopes that are under 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps open and toward the front of the printer. To load envelopes that are over 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps closed and the short-edge of the envelopes facing into the printer. You can load envelopes up to the maximum fill line in the tray at one time. NOTE: Make sure set the envelope flaps are completely unfolded. NOTICE: Never use envelopes with windows, coated linings, or self-stick adhesives. These lead to paper jams and damage to the printer6cf668b.png
Feb 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson Stylus C120 InkJet Printer Logo
180 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
