Question about Karcher Garden
How to restore pressure to karcher hd7125 pessure washer?
Pressure low adjuster seems stuck or some part seized up
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
spraydoctor
  • 97 Answers
SOURCE: karcher just stopped working
It sounds like a motor capacitor burned up. Alternatively, a wire could have vibrated loose from the capacitor. Look, but do not touch the capacitor(s), as they can hold a charge that can hurt -- or even kill you.
The trick is to be certain they are discharged before handling. To do this, use a screw drive with a well insulated handle and touch the top of the capacitor where the wires are. The metal blade of the screw driver should touch both sides of the capacitor at the same time. Then, if there is any charge being stored, you will see a pop and that's it -- it is not discharged.
You can buy a new capacitor at any place that sells AC and Refrigeration supplies. Take the old one with you so they can match the microfarad capacity. Just venturing a guess here, but if you want one that fits perfectly back into place you may have to order it from Karcher (because those units are built in Europe I think).
2. The motor may have shorted (gone bad). If that has happened, perhaps you have some warranty. Electric motors are generally warranted a little longer than the PW in general. With Karcher, I don't know. If there is no warranty on the motor, it may be better to buy a new pw than to replace the motor.
3. The problem could be a mechanical issue with the pump/unlooader. However, I would think this would be the least likely scenario.
If what I've given so far doesn't get you rolling in the direction of being resolved, please followup here. I'll be watching. And if it does get you moving in the right direction, please take a sec to rate me. Thanks!
Don
Posted on Mar 24, 2012
Testimonial: "cheers mate. Your second solution was correct. The motor has had it unfortunately. Many thanks for responding and offring sound advice. "
How do I get my Power Washer to spray with soap in the water?
You will need to adjust the pressure to low pressure by adjusting the lance. This way the machine will draw chemical at low pressure.
May 21, 2010 | Karcher G3025OH Pressure Washer
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K2.91 will not switch on unless you start on low pressure adjustable detergent lance had warranty claim for oil leak Can you tell me how mutch oil should be in pump ?
The oil in these pumps are factory filled and sealed, im not sure why there would be oil around the derergent lance... it sounds like your unloader valve/bypass valve is stuck and it takes a larger flow of water to activate it (as you get more flow on low pressure)
will have to be stripped down and lubed up or the bypass assembly/head replaced if its badly scored
Dec 14, 2009 | Karcher Garden
Karcher pressure washer works only with low pressure
The inlet screen orientation is of no consequence. Either way should work fine. Check two things...
1) Many of the spray nozzles have a high and low setting at the tip of the wand (where the water comes out). See if your nozzle has any "Push-Pull" movement (with the unit turned off). If so, it might be set in the "LOW" setting and needs to be changed.
2) Located on some SIDE MOUNTED pumps is a "Variable-Volume" adjustment. It may need to be turned to increase the flow and should be marked with a plus (+) and minus (-) along with direction arrow.
NOTE: If your pump is mounted on the bottom of your engine you will not have this adjustment.
Hope this helps!
Sep 30, 2009 | Karcher G3025OH Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
Trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Nov 09, 2008 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer k2.89
pressure relief valve is stuck. can't have an air lock.
May 31, 2008 | Karcher 2500 PSI Pressure Washer
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
55 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
