Question about Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b how to install fuel lines - Husqvarna 28cc Hand Held Blower HVH 125B
spekgt
  • 60 Answers
SOURCE: how do you install primer bulb on husqvarna 125b
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
Posted on Aug 29, 2009
#1 Taper
  • 1040 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
jasonamoss
  • 77 Answers
SOURCE: can I use 40:1 premix fuel in the husqvarna 28cc hand held blower 125b
The ratio should be 50:1 per Husq.
We have some more information if you need.
http://www.jackssmallengines.com/do_it_home.cfm
Posted on Mar 08, 2012
  • 6468 Answers
SOURCE: repair broken fuel line husqvarna 125b
to replace the fuel line get a piece longer than the old one cut the last 1/2'' down to 1/3 place a stiff wire threw the hole and out the gas cap opening push the line over the hose and slowly pull back till the line pops out then pull the wire out and pull the line threw put the filter back on before pulling the hose all the way threw
Posted on Aug 12, 2012
plink_plonk
  • 1807 Answers
SOURCE: When I prime my Husqvarna 125b the gas pours out little vent hole next to the fuel lines going into gas tank? Dont think any gas getting to carborator?What would cause this?
1. Check the pipes to the primer bubble haven't been swapped round, as it sounds like its pressurising the fuel tank.
2. Also sounds like the fuel tank vent could be damaged, this allows pressure to equalise in the fuel tank. Generally it allowa air in but not out the tank, If fuel is exiting the tank then this could have been damaged.
Posted on Apr 12, 2013
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Apr 12, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b stalls at high rev.
The fuel hose just throught the grommet comes from the pressure side of the primer bulb, it does not have to be very deep into the tank, it is just the return to tank hose, the hose kit withe grommet and filter is part no. 545081841
Jan 13, 2013 | Husqvarna 125b Hand Held Leaf Blower
Fuel lines
Fuel lines on this model just pull out of the fuel tank. they are a rubber bung push fit. Here is the parts manual for this model.
Sep 30, 2012 | Husqvarna Gas blower 125b 28cc
Husqvarna 125B will start and run but once it heats up it stalls and will not start until it cools down
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
Aug 25, 2012 | Husqvarna Garden
Repair broken fuel line husqvarna 125b
Aug 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Nov 22, 2009 | Husqvarna Garden
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 28cc Hand Held Blower HVH 125B Logo
162 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
