Question about Hitachi Televison & Video
Whats wrong with my hitachi 60SX10BA TV that worked fine but now no picture or sound any ideas
Power light would come on but doesn't now but I can hear it click when I press it.
SOURCE: No power
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
Posted on May 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: No power blinking power light
You would need to check the power supply and shutdown circuit for a faulty component. There is a manual called Toshiba power spply and shutdown circuitry available for 10.99 at the following link, That manual covers your model as well as quite a few other toshiba models. It gives step by step instructions on what to check, And the site offers ree unlimited support to help you with your diagnosing. They will een email the manual to you instantly if you returnto the site and click thecontact us link requesting that they email it instead of mail it. Here is the link just click on the Toshiba section and go through the pages of listings you will find it listed there.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2008
  • 1694 Answers
SOURCE: Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Posted on Mar 05, 2008
Shuttle83
  • 1139 Answers
SOURCE: Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
Posted on May 31, 2008
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Posted on Jan 18, 2009
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
I have a Hitachi 65F59A TV. We turned it off one
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 01, 2009 | Hitachi 65F59A Television
Hitachi rear projection tv with no picture or sound
Depends on how old it is and what the model number is. Do you think all TV's are the same man? No they are not.
Mar 08, 2008 | Televison & Video
Mar 05, 2008 | Televison & Video
Help
Sounds like a blown fuse in the power supply
Jan 18, 2008 | Hitachi 57S715 57" Rear Projection HDTV
Hitachi shows double image and then no picture or sound.
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 07, 2007 | Hitachi 57TWX20B 57" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
