Question about Behringer Music
WIRING DIAGRAM FOR DUAL WOOFER SPEAKERS - Behringer Music
    Sergeant:
    Champion:
  • 214 Answers
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
No woofer sound from my K3000FX. Verified all cables and settings correct- but sound only comes from tweeter. What could it be?
Step 1:
Hate to say it, but possibly a blown speaker. To check this, do the following -
Step 2:
Insert headphones into jack to verify for sound there.
Step 3:
Unplug unit and open rear panel to reveal speakers.
Step 4:
Remove leads from woofer.
Step 5:
Using a multimeter, set to OHM (horseshoe) to lowest setting.
Step 6:
Apply red(+) and black(-) to speaker leads. Meter should read at least 4-8 ohms of resistance.
Step 7:
If no reading, then voice coil is blown.
Step 8:
If no meter available to use, the use a 9 volt battery by applying direct connection to speaker leads in an off-and-on fashion - You should hear a "click" sound come from speaker. If no "click," then speaker is blown.
Step 9:
If click is heard, and resistance on meter is correct, then the amp circuitry leading to the woofer may be blown = repair needed.
Jan 18, 2013 | Behringer Ultratone K3000fx 300w Keyboard...
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
What size fuse do i need to use for my speaker protection kit
This will be based on the 501 model as you did not give a model Also I am assuming speakers are 8 ohms which I have no firm information for the Tannoy, but they should be marked when you open the unit. We are allowed 40 watt RMS for the woofer and 20 watts RMS according to the specs. They do not tell us what impedance the speakers are so we will do calculations based on 8 ohm speakers... if yours are different, then recalculate; P = I^2 * R so for 40 watts and 8 ohms then I squared = 5 or the current is about 2.3 amps max... You COULD use a 2.5 amp fuse, but if they were my speakers I would use a 2 amp fast blow which gives a bit of margin for the woofer. Now for the Tweeter we have I squared is 20/8 so this comes out I squared equals 2.5 or taking the square root we have 1.58... you could use a 1.75 amp, but if they were mine, I would use either a 1.5 amp or even a 1 amp as the tweeters seem to get blown in these. ALL of these calcs are based on the specs of power for the 501 model and ASSUME 8 ohm speakers... Recalculate if your units have different impedance thaan the assumed 8 ohms.
Jun 22, 2011 | Tannoy Studio Monitor Speaker Protection...
Somehow have managed to remove wires from drivers (while trouble shooting svt 410 hlf cab) while not labeling them properly for reinstall. so far have not been able to locate a wiring diagram for inside...
Most schematics won't even have any colors listed... so let us have you try this:
Find a system ground someplace like the sleeve of a 1/4 inch jack... Using an ohmmeter check for continuity to the available wires that are disconnected. ASSUME that those showing a low resistance will go to the "-" terminals of the drivers. If you have say a black and red... expect that the black will be one of the grounds... often the red then will be the (+) of the woofer. If you have whites and yellow... OFten the white will also have continuity to ground and be the (-) for the tweeter and the yellow then to the (+). Now since your speaker has 4 woofers we need to be careful to wire then correctly to get the 4 ohm impedance of the cab. IF each woofer is 4 ohms impedance, then we need to wire them in series-parallel. The shell of input 1.4 inch jack will likely go to black wires... two of the speakers will have their (-) terminals connected to these. The tip of the 1/4 inch jack will probably connect to one or more red wires. These will connect to the (+) terminals of the OTHER TWO woofers. Next one of the available (-) with no connections will tie to the (+) terminal of one of the first two woofers. SImilarly the remaining (-) terminal of one of the woofers will tie to the last (+) terminal that is vacant. Note the + of the horn will tie probably to the High level pot and this will tie to the crossover someway.
Here is a site with general schematics.
http://www.bcae1.com/spkrmlti.htm
May 02, 2011 | Ampeg Svt-410hlf (4x10" 500w Svt Bass Cab)
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
I own jamo speakers CL 30. One of the woofers is broken. Can i find anywhere one woofer to replace it?
Best to have it reconed ! The speakers need to be matched pair.
If you are using these for music instrument(s) make sure they are intended for that use. Home stereo speakers won;t take the power that music instrument speakers are designed for by a factor of say four.
If these are mis-applied, don't waste money repairing, but buy instrument grade cabinets.
Dec 26, 2009 | Music
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
43 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
