Question about Marantz CD6004 CD Player
How do i reset a Marantz cd6005?
I need to reset the system
  • Marantz Master
  • 15,171 Answers
Here is the manual for the machine. I don't immediately see anything that says 'reset'.
Posted on May 09, 2014
When my Marantz cd6005 goes on stand-by, my speakers starts to make noise, the cabinnet on the cd-player feels a littel electric.
This is a little bit of voltage leak from the PSU through the capacitors on the power board. If you know how to use a soldering iron you can replace the caps yourself. Go for the same uF rating. The same or slightly higher voltage rating will be fine. Choose 105 deg C rather than 85 deg C temperature rating; they'll last longer. Also, pick a decent make. Panasonic are good.
Sep 10, 2014 | Audio Players & Recorders
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
Sep 02, 2014 | Marantz Audio Players & Recorders
How to factory reset marantz sr6006
Hope this helps: How to reset the SR6006
Microprocessor reset (p. 150 Owner's manual) - Press and hold the Zone Select/Display buttons while powering on the AVR ......release 4-5 seconds later
Network reset - Press and hold the M-Dax/Display buttons (resets network card and does a microprocessor reset)
Jul 17, 2014 | Marantz Audio Players & Recorders
Reset cd6005
The manual doesn't show a reset switch. So just unplug it for a while (2 hours) and then plug it back in and try it again.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
May 09, 2014 | Marantz CD6004 CD Player
Reset Marantz sr5006 to factory settings
Hold the 'display' and 'zone select' buttons, then press power. Display should blink all segments. Let go of buttons, and your good to go
Jan 22, 2013 | Marantz Audio Players & Recorders
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
Tried to reset timer on marantz VP4001 projector. Unsuccessful as now unable to get it out of stand by mode
Helo
Just unplug the device and let it be at this state for about 1 horur or so. After that replug it and see whether it helps you. If not, check whether its cooling fan is working wnen you switch it ON. If not, the system must be resetted; and need a factory service. OK.
Sep 20, 2011 | Marantz VP4001 DLP Projector
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
How to reset the lamp timer on a Marantz VP8600 Projector
To reset the lamp timer for the Marant VP8600 you will need your remote.
Step 1: Make sure the PJ is powered on
Step 2: Press the leftt arrow key, then right arrow key, then the Freeze button
Step 3: Press enter to reset
Sep 26, 2008 | Marantz VP8600 DLP Projector
Having trouble setting up sound system
I can see by the setup of this device, it can be confusing. So let's make sure you are setting the device to the correct "A" speaker outputs. These would all be on the rear panel, on the right side of the receiver. Is this correctly setup?
May 26, 2008 | Marantz SR-7200 Receiver
Marantz CD6004 CD Player Logo
268 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
