Question about Marantz CD6004 CD Player
Reset cd6005 how do i do a system reset?
    Sergeant:
    Champion:
  • 214 Answers
The manual doesn't show a reset switch. So just unplug it for a while (2 hours) and then plug it back in and try it again.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
Posted on May 09, 2014
When my Marantz cd6005 goes on stand-by, my speakers starts to make noise, the cabinnet on the cd-player feels a littel electric.
This is a little bit of voltage leak from the PSU through the capacitors on the power board. If you know how to use a soldering iron you can replace the caps yourself. Go for the same uF rating. The same or slightly higher voltage rating will be fine. Choose 105 deg C rather than 85 deg C temperature rating; they'll last longer. Also, pick a decent make. Panasonic are good.
Sep 10, 2014 | Audio Players & Recorders
Tip
Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
on Dec 07, 2009 | Ford Windstar Cars & Trucks
How do i reset voicemail password on 3com 3120 phone?
On 5.0 and older software, Log into the NBX Phone system as administrator and click on "tab to it". Then click on the "security" tab under System Configuration. Click on "Reset User Password". Highlight the user you want to reset and then click "reset. The system will reset the password to the same as the extension number.
On 6.0 and later software, Log into the Phone system and go to "System Maintenance, Password Administration". Select "User Password" in the drop down menu and click "Go". Select the box on the left for the extension you want to reset and click on the "Reset Password" button at the top of the list. The system will reset the password to the same as the extension
Hope that helps!
Aug 02, 2014 | 3Com NBX 3102 IP Phone
How do i reset a Marantz cd6005?
Here is the manual for the machine. I don't immediately see anything that says 'reset'.
May 09, 2014 | Marantz CD6004 CD Player
Factory reset password admin
Below are the steps in performing the factory reset
• Unplug the power from the system.
• Hold down red reset button on back of system.
• While holding the reset button plug the power back into the system.
• After about 7-10 seconds the LED on the front of the system should start flashing rapidly.
• When it starts to flash rapidly release the reset button.
• This should reset the system. This should take about 5-15 minutes to reset and reboot. If this is done correctly it should come up with the initial configuration screen
The default admin password after the factory reset is 1234
Aug 01, 2013 | Samson Technology LifeSize Passport with...
How do you reset your PS3?
You can reset the Sony PlayStation 3 to troubleshoot the gaming system or restart after a hard drive freeze. Resetting the PS3 will restore the PS3's settings to to the default factory settings. Consider backing up any data or custom settings before doing a system reset for the PS3 as they might be erased.
instructions:
  • urn off the PS3 by flipping the power switch on the back of the system.
  • 2
    Turn the power switch back to the "on" position.
  • 3
    Hold the power button while the PS3 is powering up until you hear three beeps. These signal that the PS3 has received the manual system reset command.
  • 4
    Prompt through the initial setup menu to continue resetting the PS3.
  • 5
    Select "Format" from the system menu to format and finish a complete system reset for the PS3.
  • Dec 06, 2011 | Sony Playstation 3 (PS3) Console
    How do i reset the oil life on a 2005 gmc c8500
    Most often you need a code reader with a reset function that can connect to the computer jack under the dash and reset factory functions like that. Pain in the tush if you are changing your own oil. Mechanics and dealers have the equipment to do that reset.
    May 20, 2010 | 2006 Chevrolet Silverado 3500
    2007 FORD EXPLORER SPORT TRAC 4X4 Change oil light on
    Press and hold the SELECT/RESET
    control switch to select SYSTEM
    CHECK when “SYSTEM CHECK /
    HOLD RESET” is displayed in the
    message center. Selecting this
    function from the SETUP MENU
    causes the message center to cycle through each of the systems being
    monitored. For each of the monitored systems, the message center will
    indicate either an OK message or a warning message for two seconds.
    Pressing the SELECT/RESET control switch cycles the message center
    through each of the systems being monitored.
    The sequence of the system check report and how it appears in the
    message center is as follows:
    1. OIL LIFE RESET
    2. CHARGING SYSTEM
    3. WASHER FLUID
    4. DOOR AJAR
    5. EXTERIOR LAMP
    6. BRAKE SYSTEM
    7. PARK BRAKE
    8. MILES TO EMPTY
    9. FUEL LEVEL LOW (will only display if 50 miles or less to empty)
    To reset the oil monitoring system to 100% after each oil change
    [approximately 5,000 miles (8,000 km) or 180 days] perform the
    following:
    1. Enter SYSTEM CHECK to display
    “OIL XXX% RESET IF NEW”.
    2. Press SELECT/RESET control
    switch to display “HOLD RESET IF
    NEW OIL”.
    3. Press and hold the
    SELECT/RESET control switch for
    more than 2 seconds. Oil life is set
    to 100% and “OIL CHANGE SET TO
    100%” is displayed.
    Apr 02, 2009 | 2007 Ford Explorer Sport Trac
    Mac will not add printer
    Hi, try to reset the print system as the apple article below:
    SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
    Products AffectedMac OS Printing/Fax (any version)
    What does Reset Printing System do?
    • Deletes all printer queues and jobs.
    • Resets all printer settings to their default by deleting configuration files.
    • Performs a permissions check on the /tmp directory.
    Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
    Resetting the printing system in Mac OS X 10.5.x
    1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
    2. Choose System Preferences from the Apple menu.
    3. Choose Print & Fax from the View menu.
    4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
      As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
    Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
    1. In the Finder, choose Utilities from the Go menu.
    2. Open Printer Setup Utility.
    3. From the Printer Setup Utility menu, choose Reset Printing System.
    4. Click Reset.
    Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
    Mar 14, 2009 | Apple Computers & Internet
    Marantz CD6004 CD Player Logo
    135 people viewed this question
    Top Marantz Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
