Question about Electrolux E44LB60ESS
Can I get instructions on changing the main burner
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon David,
I understand that you are looking for instructions on how to change the main burner on your Electrolux grill, model# E44LB60ESS. This is typically not a do it yourself repair. I do recommend contacting your local authorized technician for repair as they would be more familiar with your grill. I hope this is helpful.
-Best Regards-
Posted on May 12, 2014
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
How do I change the burners on a fd27lkec grill?
Good Afternoon Friend,
I understand you are trying to change the burners on your Frigidaire grill, model# FD27LKEC. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the burners with ease. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FD27LKEC (LP) Grill
Hi I have purchased a 2nd hand Colman 431 stove . The instruction Manual wasn't with it. Looking for instructions Please. Hope you can help. Rob Tyler Toronto
I am not sure what to tell you, other than go to Colman's website for a manual. That will at least give you a parts list if you ever need it. But, these stoves are generally solid and reliable, with few things to know about.
What I do to operate:
  1. Set up stove: lid up and wings out, tank fully pumped (works best if no more than about 2/3 to 3/4 full) and installed with nozzle firmly into the socket above the right burner.
  2. Little lever on left of valve assembly--turn upward. Open valve a little bit to get fuel flowing to burner. Give it just a few seconds then light burner with match or lighter (watch your fingers!). It should light off pretty readily.
  3. Open valve a fair bit (anti-clockwise) and let it burn for up to a minute until the flame changes from yellow to mostly blue, and mostly around the burner and not up in the air. Turn little lever on left of valve downward.
  4. Re-pump tank to maintain pressure.
  5. Use valve knob to adjust flame intensity, and cook away.
  6. To use second burner, the key thing os to remember that it draws from the same valve, so when it is on the main burner goes down a bit.
  7. The knob for the 2nd (left) burner is a little flip-out on the left end of the stove. Open slightly, and light the burner. Only do this after the main (right) burner is burning blue.
  8. Use the main valve (on the tank) to adjut the total fuel flow, and the little handle for the left burner to adjust how much of the total flow goes to the left side. (You cannot burn the left without the right being on.)
  9. Pump as required to maintain pressure.
  10. The only real "part" that you might have to strip or replace is the "generator" which is the tube from the valve across the top of the right burner. The liquid fuel is vaporized in there, and is what needs to get warmed up when you start.
Feb 01, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Changing from nat. to lp gas on water heater, changed main burner orfice and pilot orfice and switched the pressure regulator to lp gas, is that it??? the label on the water heater says something about...
YOU MUST FOLLOW THE MANUFACTURERS CONVERSION INSTRUCTIONS EXACTLY. If you do not your homeowners policy COULD be declaired void in the event of a claim. More importantly (IMHO) you could create a dangerous situation!
Sep 18, 2009 | Rheem 81VP6S/430126 Water Heater
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Grilling Logo
48 people viewed this question
Top Electrolux Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Electrolux Grilling Expert? Answer questions, earn points and help others
