Question about Music
How to set up a behringer pmp 2000
How do you set up a pmp 2000 with the speakers and floor monitor and what size monitor speakers do you need
  • ian hewitson
    ian hewitson May 09, 2014
    do i have to match the speakers main speakers 200w continues and 800w peak power do i have to match the floor monitor to the same wattage
  • BJ Russell May 09, 2014
    No, just don't exceed the power ratings on any of the individual speakers
    Sergeant:
    Champion:
  • 214 Answers
Http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
Posted on May 09, 2014
My speaker processing button not working which makes one of my speaker not work, can this be repaired.behringer Europower pmp 6000
Yes, most anything can be fixed. However, Beheinger is deadly slow shipping parts to repair shops, should it need a Behringer-specific part.
To find your. Nearest service center, contact Behringer support.
MUSIC Group
Dec 19, 2016 | Music
Behringer PMP 2000 lost audio output
Sounds like a few capacitors have just blown, easy fix if your handy with a soldering iorn,
Aug 01, 2014 | Behringer PMP2000 800 Watt 10 Channel...
How to set up a pmp 2000
What you need will depend on what you are doing with it (what sort of venues and how you are making music - what sort of band/solo with backing track etc.) You will need a monitor with an amp or a powered monitor. The key thing is that you'll be able to hear the monitor mix over the rest of the PA. If you are just putting vocals through it you would possibly be best with a 12" but otherwise go for a full range unit with 15" and horn. Power wise I would suggest you need something capable of generating at LEAST 125dB unless you are in a quiet acoustic set. The SPL from the monitor is much more important than the power since power has little bearing on SPL.
May 09, 2014 | Behringer Music
Our Behringer pmp 6000 just recently mysteriously lost both monitor 1 & 2 signals. Please provide some suggested resolutions? Is there anything other then the channel monitor level knobs and the main...
Try plugging in a set of headphones into each of the mon left and right. If the monitor sliders are up AND the channel monitor knobs are up you should be able to hear in ONE SIDE only of the headphones. If not, then you may have failed to power your monitor amp or speakers from the SAME receptacle as the mixer and this can result in ground bouncein building wiring that will blow out the driver chips for the mon signals.
Nov 01, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My pmp froze, tried to reset it but now it wouldn't power up
Your PMP what? Is this a Behringer?... and if so what model?... If it won't power up, for goodness sakes do NOT replace a blown fuse as additional damage usually results. Get it serviced... if under warranty, then exercise the warranty. If it is a BEhringer, then also read my tip on Fixya tips regarding PMP mixers and a hazard of using 1/4 inch plug speaker cables or adapters.
Sep 19, 2011 | Music
We set up the monitors in our pmp 6000 at the mon send jacks but we didn't get any sound from it when we turned up the monitor volumes. What is the proper way to set them up?
I HOPE you know that the monitor send jacks are NOT powered. You MUST use either powered monitors or an external amp for these to drive speakers. Assuming you have done that, you have to turn up one or both of the monitor knobs for each channel you wish to send to the monitors at the desired level. Then you advance the monitor faders for the overall monitor level.
May 16, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
I want to connect two passive b212 and 6 active b215 , i will use two active b215 for monitors ..... i am using a PMP 3000 Please advice,also where can i get a detailed numbered illustrations sheet for...
The passive speakers connect to the main outputs using Speakon connectors on the back.
You will use Balanced connections (TRS) to the main L and R connections on top to the active speakers. Daisy chain 3 active on each of the L and R top connectors.
You can download a user manual if you don't have one.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
ALSO PLEASE read my tip regarding a hazard when using Speakon to 1/4 inch speaker cables on channel "A" in the FIXYA tips for PMP mixers. The barrel of the channel A 1/4 inch is the HOT side of the signal to the speaker instead of the tip.
Nov 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I need a fuse for my Behringer pmp 2000 mixer. How can i buy it.
Try Mouser electronics. Their website mouser.com is easy to navigate. The will ship just the one fuse if you need it. If you know the size and type of fuse they are usually the cheapest. You can also try Radio Shack. They also carry a large selection of fuses.
Jun 14, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
145 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
