Question about Kitchen Appliances - Others
Slush machine not freezing
It powers up spins around maybe fine gas? or compressor? it was working fine before it got shipped to me it was a courier I arranged to pick n drop to me maybe the moved it up n down but its not damaged looks perfect I am new to this don't even know how to add flavour I just bought syrup from cash n carry n dumped it in PLEASE help me
  • sammoz
    sammoz May 12, 2014
    i tried syrup with water for 1 hr then syrup only 1 hr then water only 1 hr no ice at all tried it on high temperature n low nothing works
  • 2,236 Answers
If it doesn't get cold at all, you have a refrigeration leak. if it gets cold but doesn't freeze, maybe just low refrigerant or the timer is on defrost
Posted on Sep 08, 2014
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
I have a sunsip slush machine and is not freezing, and machne is running for nearly 6 hrs
if the mix is cold but not freezing, you may be low on refrigerant or the timer is in defrost (if it has that feature). if it's warm, either the solenoids are not opening or there is no refrigerant. check the exhaust. if there is little air flow, clean the condenser coils (air intake). if it's cold, the compressor is not functioning or no refrigerant. for low or no refrigerant, you have a leak. take it in for repair
Jul 21, 2014 | Kitchen Appliances - Others
Ugolini slush machines
check the left side condenser coils, make sure they're clean. there might be low air flow, and that'll cause the compressor to overheat and shut off. leave at least 6 inches of space on both sides of the machine for it to breathe. also if the ambient temp is too hot, same thing.
Jun 26, 2014 | Kitchen Appliances - Others
Frutina slush machine
if the compressor is running and it's not freezing, it may have low refrigerant. need to have a professional recharge it. if the compressor is off, check the defrost timer (if your model has one) to see if it's on defrost.
Feb 08, 2014 | Kitchen Appliances - Others
Cab Faby Not Freezing
could be any number of things: mixture being too rich (add more water), timer is off (reset defrost timer on side), 4-minute timer is not turning on compressor (inside right front panel. unplug thin blue wire harness, turn middle screw until compressor turns on), the refrigeration solenoids (is there a click from the back when you turn the switches on), does the compressor turn on, does the fan turn on (if there is no air flow, the overpressure sensor will turn the compressor off), or maybe there is a leak. if it is the last case, you will need a professional to take a look at it.
Nov 23, 2013 | Faby Cab S.p.a Faby CAB Frozen Drink...
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
Parrot ice slushie machine Compressor comes on,
Liquid gets very cold but won't freeze
Jun 10, 2010 | Freezers
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
OIL FILLED COMPRESSOR SEEMS TO FREEZE UP ???
Cold weather will freeze the water the compressor normally makes and this can prevent the motor from driving the compressor. Drain the tank and warm it up as needed......
Jan 10, 2010 | Craftsman Air Tools & Compressors
My slush machine wont freeze
the first thing i would check depending on your make and model is ensure the compressor is running
if not check the overload and relay pluged in on the side for continuity
then make sure your cooling fans are working
this should be a good first step but let me know
if not let me know the make model and ill take a look at the scematic
Oct 24, 2009 | Grindmaster Freezers
Kitchen Appliances - Others Logo
151 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
