Question about Maytag MAH6700AWW Neptune Front-Load Washer
Why maytag neptune washer water pouring out soap dispenser door?
Why is water pouring from my soap dispescer?
  • 20 Answers
Either there is a sock stuck between the inner tub and the water
inlet to the tub or more likely you have been using to much liquid detergent and cold water wash all the time . This can cause the supply tube below the dispenser to be plugged up. Have fun cleaning it. Warm wash should always be used. Detergent needs the heated water to work properly .
only other possibility is mice building a nest if the washer hasn't
been used in along time.
Posted on May 09, 2014
Front-end door is locked. Can't open it.
Yes there is a plastic lead inside front of soap powder dispenser. Sometimes you have to remove screws from dispenser to gain access to it. JUST PULL IT & THE DOOR WILL OPEN.
Dec 19, 2013 | Maytag Neptune MAH6700A Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
    My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
    Dec 27, 2009 | Maytag Neptune Washer
    Water is pouring out of where the soap dispenser is. Can anyone help?
    its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
    If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
    If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
    Hope that helps!
    Jul 09, 2009 | Kenmore 43142 Front Load Washer
    We have a Maytag front load washer Model MAH 4000 AWW
    tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
    Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
    Maytag front loader washer--door won't open but lock light off
    Open the soap dispenser. Look down in front of the fabric softener dish.
    You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
    The door should open.
    If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
    Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    MAY8700AWW LEAKING WATER UNDER DOOR AND S/B/F DISPENSER
    Service came out to check out my washer. He sent it thru the wash cycle and it started leaking. He removed the top and checked the hose that leads from dispenser to tub. What he found was the round piece of paper from the clorox top which had dropped into the dispenser apparently when I poured clorox into the dispenser. Which was causing the dispenser to backwash underneath and flow down like it was coming from underneath the door. Thank God I have an extended warranty. I advise everyone who has the newer digital models to purchase an extended warranty. It is worth it....the repair can be costly from what I understand.
    Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune MAH8700AWW Front load
    I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
    Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Maytag MAH6700AWW Neptune Front-Load Washer Logo
    88 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
