Question about Nova Kool RFS7500 7.5 Cu. Ft. R/F
Door does not want to firmly close - Nova Kool RFS7500 7.5 Cu. Ft. R/F
  • 742 Answers
Ther are adjustments you can make on the hinges.
Posted on May 12, 2014
Adjust true prep table door
There are plastic cams in the hinges that wear and are replaceable. A company called Case Parts supplies a lot of refrigeration hardware like that and the web site should help and another company is called Refrigeration Hardware. The parts breakdown will show you what I mean. Hope this helps and good luck.
Oct 10, 2014 | True TSSU-48-12D-4-ADA 49" ADA Compliant...
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Apr 18, 2014 | GE FUF17SVRWW Upright Freezer
The door does not close on its own
You might want to check the bottom of the door and see if its dragging and make adjustments if it is. Also there are plastic cams at the door hinge pin area that are supposed to help the door close. They get worn and may need to be replaced. You can lift the door off of the hinge pins and inspect them. hope this helps and good luck.
Feb 10, 2014 | Kolpak Freezers
Where is the ice maker reset button on a Samsung RS265TDRS?
This ice maker is on the door, so
remove ice bucket
move your fingers up under the ice maker tray guard on the left side until you find a button
you may have to press this several times, perhaps hold down firmly until you see some action
then quickly replace bucket & close door
Sep 06, 2013 | Samsung RS265TDRS 25.5CuFt Side-by-Side...
Gasket seal is not good
Check the door is aligned properly and meets all the way round If not, grasp the door firmly at the top and push it closed while placing the head of a mallett or similar item between the bottom of the door and the body of the fridge. This will straighten the door and the seal will fit again
Apr 22, 2012 | Kenmore Freezers
Door does not stay sealed when closed.
first make sure there is nothing inside stopping the door from closing , the freezer should be level, and the door should swing close on its own free will. the door can be tweaked by bending it back into shape .or by setting the top hinge bracket, it should have three 5/16 bolts, that will alow you to ''square the door''. but most of the time it's something in the way of the door.. look close and remove some items that you think might be in the way, then remove some more
Aug 08, 2011 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Door will not stay shut, nothing is blocking it, no suction sound when it closes
1. Check entire condition of seal, even the bottom section and make sure it is not damaged.
2.Check the seal on the side of the door the hinges are on, they may be catching on the cabinet when closing, if so, use petrolium gel and rub it on the face of the seal, this will allow lubrication of the seal.
3.Also check that the seal has not swelled , if so, you can rectify this by using a hair dryer and starting on the sides the hinges are on, carefully heat the outside of the entire seal on that side, then close the door and hold firmly closed till cool, then move to the other side, top, then bottom doing the same process each time, this usually works a treat.
I hope that has been of some help for you and it works.
Please dont forget to vote, thankyou. regards Russ
Mar 09, 2011 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Nova Kool RFS7500 7.5 Cu. Ft. R/F Logo
78 people viewed this question
Top Nova Kool Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Nova Kool Freezer Expert? Answer questions, earn points and help others
