Question about HP Officejet 9110 All-In-One InkJet Printer
HP officejet 9110
Trying to reinstall software....1) software does not show up on the add/remove menu from control panel - I don't know how to uninstall it manually, can cannot find the files when I search. 2) software does not complete installing, it locks up and then when I try to cancel it says it isn't finished (even when left alone over night).
  • Jemmy Jem Nov 12, 2007
    no. I am installing on a PC. Another HP actually.
  • 1,601 Answers
Are you installing on a MAC?
Posted on Nov 12, 2007
I am trying to scan a page and it is telling me no scan options are available.
You don't say how you're trying to scan.
You can scan by pressing the Scan button on the printer control panel or by opening the HP Solution Center program and clicking on Scan.
If neither of these options work then connect and disconnect the printer cable and if necessary test a different cable.
If none of the above fix the problem, the printer control program is probably either corrupted or partially deleted, so uninstall the program and all its components in Add or Remove Programs and then reinstall the program using the Easy Install option.
Start > Control Panel > Add or Remove Programs (Uninstall a Program) > highlight - Remove.
If you don't have the driver and applications disc, you can download them from: or your country specific HP site.
I hope this helps.
Aug 25, 2011 | HP OfficeJet J4580 All-In-One Laser...
How do you open the HP OfficeJet Pro L7680 and remove the hard drive?
It's simple need to look in control panel then add remove programs and delete the hp officejet program then restart the computer and reinstalling the program
Nov 27, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have Windows XP. I have been printing on both sides with HP J5780 for a long time. I didn't change anythin that I know of. Now the number 1 shows up in the o page line even though the o all line is...
You should try uninstalling your printer and reinstalling it. This can be down through the software you installed with your printer via control panel - add and remove programs. Also in control panel printers and faxes and remove your printer. Once done this go to hp's website and download the latest driver (see link) and install it. That way you have the up to date software.
The link was taken from the hp website for your exact model if this does no work see below.
Nov 13, 2010 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 9110 scan function drivers required
Below is the link where you can go and download the drivers and firmware for the HP Scanjet 2200C Flatbed scanner.
Click Here to download
Please let me know if you have any further questions or concerns.
Feb 23, 2010 | HP Officejet 9110 All-In-One InkJet...
I am trying to renstall drivers and software for HP OfficeJet G85
ok you can find the add and remove button in control panel to remove the older version.
go to start menu then control panel
Apr 02, 2009 | Apple HP Officejet G85xi InkJet Printer
Horizontal pink & blue lines across color pictures that I print.
In the past when I have seen this on my old printers, it is the color cartridge. Eithe the haed is cloged or it needs to be replaced. You could try to take the color cartridge and set the print head(copper colored end) on a damp towel for a little while and see if it will release the clog. (HP uses mostly water base inks and they dry out sometimes) Then wipe the head on a dry cloth. Reinstall and try again. You should also have software for HP to prime the head and clean it. Try that and if you still have problem, replace color cartridge.
Mar 03, 2009 | HP Officejet 9110 All-In-One InkJet...
I wish to print but it will not print so I decided to re install the software, however, HP 4100 all in one will not uninsall and the error says the uninstaller is not working.
try reinstalling OS if possible.
try other methods, like Add/Remove Programs... from control panel to remove old softwares.
If you are an expert try removing the same from your file system / registry...
Dec 29, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP 9110 all in one's scanner will not work
I have a 9110 and a laptop running Windows XP and Internet Explorer 7. Prior to upgrading the IE from 6 to 7, I was able to run the HP Director and fax, scan, whatever from the laptop. After upgrading to IE 7, HP Director quit working. I contacted both Microsoft and HP and they pointed fingers at each other and said yes, upgrading to IE 7 broke the HP Director. Both said fixes were being developed, but that was months ago and I have not heard of any fixes.
I did find a workaround that allowed me to scan documents to the PC (faxing worked fine manually). Assuming the 9110 all-on-one’s drivers are still on the PC, and that the PC is connected to the 9110, go to “start, settings, control panel” and once in control panel, select “scanners and cameras”. If the drivers are still there, you should see the HP 9110 under “device”. Highlight the HP 9110 and double click. A wizard should start and it will guide you through the scanning process. If the 9110 does not appear in the “scanners and camera” box, you will need your 9110 CD and click on “add an imaging device”, which will start another wizard. It’s not as easy as using HP Director, but at least I can use the scanner. Hope this works for you.
May 08, 2008 | HP Officejet 9110 All-In-One InkJet...
Scanner won't work, printer and fax work
reinstall the print management software. May need to remove the printer, and re add under control panel. Got backup?
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
