Question about Polaroid 3211TLXB 32 in. LCD Television
Why does my polaroid 3211-tlxb have neon colors?
I have a polaroid 3211-tlxb that displays only neon colors. i replaced the power supply as it was the original part that went out. thats when the neon colors started. then i replaced the main board. the issue is still there. what else could it be?
  • 191 Answers
SOURCE: Polaroid " 3211 TLXB red light no power
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Posted on Oct 12, 2008
SOURCE: screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Posted on Sep 05, 2009
rulds2008
  • 3866 Answers
SOURCE: Polaroid 4011-tlxb. Power to tv and it was turning
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Posted on Sep 22, 2009
ladywinn
  • 5138 Answers
SOURCE: Polaroid flm-3701. Power supply is putting out 5
Look on power supply board for Bad capacitor 2200uf 25v or 1000uf 16v if it is puffed up on top it is Bad, also Main Board is the tuner board
Encompass Parts has some parts in stock for this TV and Free service Manual you can download online 1-800-638-3328 and for capaciotrs Call Mats 1-800-628-1118
Posted on Dec 07, 2009
budmrtn
  • 11361 Answers
SOURCE: 40''polaroid lcd(4011TLXB) has power to it but no
Power supply module is to supply voltages to the main control board (the board where the TV cable and video cables are connected to), backlight inverter board. You can buy the whole control box which has both board assembly (power supply and the main control board): http://www.shopjimmy.com/catalogsearch/result/index/?q=Polaroid+4011-TLXB+&limit=25
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 25, 2010
My polaroid 3211-tlxb tv wont power on
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 24, 2015 | Polaroid Televison & Video
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid 3211-TLXB has funny colored picture quality. Turns on and off fine and sound is fine.What could be the source of the problem??
Sounds like T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Polaroid Televison & Video
I have a Polaroid 3211-TLXB -It starts up fine-everything works great - then after 10-15 minutes it freezes + picture goes to crazy grey/white lines + volume goes to maximum-won't turn off-have to unplug -...
hi there, this may helps you a bit. Try to unscrew the back casing. visual check the power supply section. If you notice some electrolytic capacitors are bulgy or bloated, it needs to be replaced with same value and type. Felt the power transistors which one really heats up. Over heating of electronic components or part do affects the pictures. this also need to be replace. doing preventive repairs can extend the lifespan of your TV.
Adding exhaust fan may also lessen the heat builds up on the board. Proper ventilation also helps in the performance of the TV. If this do went well maintain the fan.
Please vote and rate. Good day
Mar 11, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Common Polaroid TV Problem-no picture but sound works
Failed capacitors are common problem in LCD TV's and Monitors. Each power supply uses different caps size and value. You should inspect the power supply module first.
Please post back what you find.
Jul 25, 2010 | Polaroid 4241-TLXB 42 in. LCD Television
Polaroid 4011-TLXB Power supply blew up IC3 I need the generic IC nr. It is an 8-pin dip. It is switch mode driver IC. Please help. Larry @ central tv
Replace power supply board from PTS. No parts available for PCB.
Generic part nr for IC3 is A6252M can't find one easily.
Feb 08, 2010 | Polaroid 4011-TLXB LCD TV
I would like some help with my tv
My Polaroid TV 3211 TLXB (2007) was working fine, turned it off and now won't power up, volts on power supply are normal, red light is on. Control boxes are avaiable. Could this be the most likley problem and are they interchanable with other similsr sets. ? Thanks for any help
Feb 10, 2009 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Polaroid " 3211 TLXB red light no power up?Ive checked for Bad Caps,on the main power supply.I found none,that were swollen or leaking.It looks good.I checked volltage out to volltage inverter.all the out...
Oct 12, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Lost remote
what kind of universal remote are you trying? They're all different
Sep 12, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid 3211TLXB 32 in. LCD Television Logo
24 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
