Question about Moen Plumbing
Moen connector how to get connector to seal
  • 141 Answers
Use plumbers white Teflon tape around the threads in a clockwise fashion or use plumbers putty
Posted on May 09, 2014
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I have a single lever Moen Kitchen faucet that is leaking around the base on top what might be wrong with it
    You need to replace the spout o-ring seals. A Moen #117 spout oring kit. If you have a faucet with a sprayer, you will use all three rings. If uit has no spray, you will use only two.
    Apr 19, 2016 | Moen Plumbing
    I am having a leak with the hydrolock going to the sprayer hose on a new Moen faucet. I have taken it apart a few times to make sure it's together right, but I can't get it to stop leaking.
    Three years ago, I installed a Moen kitchen faucet with sprayer
    in one of my rental units. Moen twice sent replacement
    Hydrolock kits, as I couldn't get them to seal. While waiting for the Moen parts to arrive, I used a short length of heater hose purchased at AutoZone, held on by two small hose clamps. After all three Hydrolocks had failed to seal, I just left the heater hose in place. Three years and no problems. ..and no more Moens, either.
    Sep 16, 2011 | Moen 87530 Touch Control Single Handle...
    Installed a new moen adler tub faucet with shower diverter. When you turn on the shower water continues to come out of the tub faucet. Is there an adjustment or is it just the way it is??
    Our Moen always dribbled a little since the diverter is metal-to-metal and doesn't really have any seal. The loss shouldn't be a stream though.
    Nov 11, 2010 | Moen & One Handle Tub & Shower Faucet
    I purchased a moen lavatory sink pop up yesterday, installed it but water trickle down through the threads, it came with a bubble type rubber seal a flat rubber seal and a plastic washer/seal . I tried...
    When you installed the new drain unit, did you put "plumbers putty" on the underside of the flange when you put it in the sink bowl? There should be a plastic type washer that gets squeezed on the plastic ball of the pop up mechanism to seal that area also. And the bubble rubber seal probably is the one to use with the flat plastic washer when tightning the big nut on the bottom. Make sure all three of these areas get sealed properly.
    Aug 29, 2010 | Moen 103459 Drain Pop-UP Plug
    Replaced moen teo handle cartridge 1224 now faucet
    the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
    Jul 19, 2010 | Moen & Replacement Cartridge
    Installed new Moen posi-temp cartridge. Hot & cold water is correct but water will not shut of*** the way.
    I just had the same experience, except I used a non-Moen cartridge. (It was from Ace Hardware, and Ace told me that Danco was the manufacturer.) When I pulled the cartridge back out, one of the two hard plastic seals on the side of the cartridge had torn, presumably on the sharp metal opening on the water supply pipe. I'm guessing there's something wrong with one or both of the seals on your new cartridge.
    Jul 13, 2010 | Moen Posi-Temp Single HandleTub And Shower...
    I am reinstalling a Moen 7345 riser faucet in my laundry room. This faucet was removed from a bar sink two years ago by the contractor who replaced my kitchen counters and changed my two kitchen sink...
    I had a similar problem and, like you, found that there was nothing for the washer to seat against. Apparently, there was a metal bushing installed when manufactured, that was entirely eaten away by electrolytic corrosion - mine took nearly twenty years. I machined a new non-metallic bushing, installed it, and the problem was solved.
    I also sent Moen's president a letter explaining the problem and how to fix it but heard nothing back from them. At the time, no parts were offered that could fix the problem.
    Jan 30, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Plumbing Logo
    51 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
