Question about Intex Krystal Clear Saltwater System Pool Chlorinator 54601e
Why does my new intex saltwater system keep alarming low pump flow even after i connected a new filter pump, checked the flow sensor and cleaned the titanium
I have called intex 2 times and tried everything they suggested with no success.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intex Master
  • 1,448 Answers
Are your filters clean? try running without cartridges if it still errors out sounds like something is caught in the pump impeller
Posted on Jun 10, 2014
Help with low flow on intext krystal clear saltwater system.
You can check the inlet line where it comes from the pool... Their is a little sreening/filtering system in the the parts that screw together and connect the valve to the pool... When I unscrewed mine, it was jammed with bugs, leaves, green algea... That did the trick for me... I am sure you already changed/cleaned the filter in the filter/pump that comes before the Salt water system... That will cause low flow as well...
Jun 04, 2014 | Intex Automatic Salt Water System for ...
Why do i keep getting the low pump flow alarm?
are filters clean? if so check to see if impeller on pump is plugged sometimes hair and debris get caught in it
May 15, 2014 | Intex Krystal Clear Saltwater System Pool...
System keeps alarming low pump flow yet flow is excellent with a new filter pump in place...how do i stop this alarm?
is pump hooked up correctly? if so are filters clean? try running without filter cartridges in to see if more flow otherwise need more info
May 09, 2014 | Intex Krystal Clear Saltwater System Pool...
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
Low flow light will not go off. green light will come on for about 10 mins. changed filter, cleaned flow sensor, checked hoses.....
If you already checked the flow sensor as described on this instruction, I would call INTEX at
1-800-234-6839
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Bought saltwater system last year ~ loved it!!! This summer the system continues to say, "low flow" and now the water is almost green???? Help!!!
Keep in mind, as soon as the system detects low flow, it turns the electrolytic cells off to prevent from burning them up.. If you have good flow and still get this alarm, check the flow sensor for dirty, stuck, defective or broken. See picture below..
Jul 11, 2011 | Intex Automatic Salt Water System for ...
Low flow keeps alarming
the manual doesn't tell u but the obvious solution is debris trapped in the filter that water flows from the pool to the pump. The one screwed into the pool liner. Unscrew the Blue cover , the one on the inside of the pool, and u will be surprised how much junk gets trapped in there, clean it out once and week and after vacuuming the pool
Jun 04, 2011 | Intex '10 Saltwater System Pool...
System is completely clean (all areas) and it still beeps low flow when we try to get it to clorinate. Is the sensor gone?
If you have checked intake and outake valves at pool end for clogs and opened all the way, cleaned skimmer if using one. checked for blocked air in the system, made sure pump filter is clean, confirmed water is going into the salt generator on right side, and out on the left side, checked that the flow sensor isnt loose, checked that the flow sensor hinge/flap moves freely and is clean, checked that the filter on the right side of the salt generator is clean (most common cause of this problem), and that the electrolytic plates are clear, and if the alarm comes back on after turning off the unit then turning it back on after checking all the above then the sensor probably is bad and you would have to contact Intex Service Center for a new one.
Sep 08, 2010 | Intex Automatic Salt Water System for ...
Hi- I'm a new intex above ground metal frame pool owner. I bought the saltwater chlorinator to go with my pool. I constantly have a problem with the pool filter not getting enough water to flow through...
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
I keep getting code 90 (low water flow) on my Intex Salt Water System for Above Pools. I imagine that it could be a result of my water filter not being powerful enough. Could be the problem. I want to be...
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater System Pool Chlorinator 54601e Logo
123 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
